Question about KitchenAid KBRA22KLSS Bottom Freezer Refrigerator
I opened the freezer and water in ice tray, ice is melting. temp up to 46 degrees.
  • Jason Kennidy
    Jason Kennidy Nov 02, 2010
    What brand? Is the rest of the machine working properly?
  • Jason Kennidy
    Do you hear any humming clicking noises? Is there ice built up on the back freezer wall? Is the fan running in the freezer?
  • KitchenAid Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 02, 2010
Whirlpool side byside refrigerator ice maker not working
Make sure freezer temp is 10 degrees or less. Is the water solenoid filling the tray? If there is ice in the tray perhaps the tray heating element is open.
Easiest fix is to replace the unit with a new one - cost about 40 bucks on ebay.
Jun 14, 2017 | Whirlpool Refrigerators
Whirlpool mod#ED5FHEXNB00 isn't making ice
Freezer temp has to be below 10 degrees for ice maker to work. Also check to see if water/ice is in the tray. If no ice in tray then the water solenoid valve is not feeding the unit. If ice in tray then the heater is not working to melt the ice a bit so it can be scooped out into the ice tray. And make sure the feeler arm is down into the ice tray bin - if not, ice maker is shut off.
Oct 05, 2015 | Whirlpool Refrigerators
Refrig door was not completely shut fof about 24 hrs temp was 50. Makes a loud noise when running and about 8 hrs after discovery has only gone to 46 degree
Listen to sound where is it coming from bottom back? Or inside near back wall . noise could be ice on or around evaporator fan if you can unplug for 12 hours leave doors open this will melt ice . if it is ice that will fix it.
May 08, 2015 | Gladiator GAFZ21XXMK Bottom Freezer...
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Water doesn't fill the ice maker trays
Most ice makers need to be at 8 to 13 degrees to make ice. If you had to defrost coil, then it's a defrost issue. Could be timer, bi-metal our heater.
Aug 17, 2012 | Refrigerators
Ice maker wont make ice
Is water getting into the ice tray of maker? If not check for the water solenoid's proper operation. Is freezer temp at least 10 degrees or less? If not, the ice maker will not work. If ice in tray then perhaps the heater element is not working to melt it a tad ans allow the fingers to pudh the ice out and into the tray.
You can get those suckers for about 40 bucks new on ebay eBayeBay
Aug 30, 2017 | Star Manufacturing GE Profile PFSS5PJX...
Model TXI 20ML Ice maker is melting ice cubes in the grooves and blocking them from falling into tray-not making any ice. Took out IM let it thaw then replaced. I increased the freezer temp from 4...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 20, 2011 | Amana Top Freezer 20.6 cu. ft. Top Freezer...
Freezer is cold, has ice on bottom. Frig side is constant 50 degrees. It is constantly running also.
the defrost has melted the ice,now the drain tray is plugged and needs a wire run down from the drain in the freezer to the condenser pan so it can evaporate,as this fools the temp thermostat trying to cool the refrige compartment to keep trying to cool the unitif theres water dripping into the fridge rom the freezer this is a good indicator of this problem
Jul 01, 2011 | Refrigerators
Does not dispense ice. Ice tray in freezer is
your haveing air cirrculation problems due to to much stuff in your freezer or fan itself isnt pushing enough air
Apr 19, 2010 | GE Profile PSS26MGS Side by Side...
KitchenAid KBRA22KLSS Bottom Freezer Refrigerator Logo
66 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
