Question about Acer AC713 17" CRT Monitor
Small vertical line . - Acer AC713 17" CRT Monitor
    Sergeant:
  • 186 Answers
You can try to degauss it, not sure if that's the problem. May be something that cannot be fixed. Bring up the on-screen menu, locate the degauss option , and select it. You should now hear the degaussing noise, and the screen will probably display a brief burst of color.
Posted on Nov 02, 2010
Black lines screen vertical
It sounds to be a COF fault. If you wish to get more details, check the site linked here. Pull up older posts. It has screen-shots to defective plasma and LCD TVs, along with some details to locate the faulty section.
Dec 01, 2013 | Televison & Video
Small vertical pink line on the screen Garmin Nuvi 3590LMT
Most defects of the picture on the LCD display, typically points toward a defective display. We've repaired a lot of units with lines, splotches, color problems, etc. just by replacing the display.
Mar 18, 2013 | Garmin nuvi GPS
DEAWOO TV Model no DTC 2975 vertical line i want to know that vertical ic number b,cos of that ic is burn & blast,i can't fine out.
If you have a bright vertical line down the screen you have an "S" correction fault. Usually there is a small choke that gets a dry joint under it.
Check for dry joints.
Jan 04, 2011 | Televison & Video
Tv not showing picture but just horizontal line.
Failure of vertical output. Check vertical output components.
Jul 06, 2010 | Sansui DTV2760 27" TV
One day my tv started having white lines in various places, then one day the scrren went white but still has a small line across the top that works fine
The problem is "Vertical Over-drive" and the white lines are vertical retrace lines. What has happened is a component failure between the vertical oscillator and the vertical driver circuit. The component is usually a capacitor that is leaking and allowing voltages to appear where they shouldn't be.problem component is leaking and allowing DC voltages to appear where they don't belong. It's causing the vertical driver transistor to run "flat out" and will ultimately burn out the transistor from internally generated heat.
Hope this help....
Jun 18, 2010 | Televison & Video
When the Automatic Document Feeder (ADF) to copy I
There are two scan modes when copies are made.When you make copies through ADF you originals go past small **** glass located to the left of the main exposure glass.Any small mark on this **** glass( correction fluid mark,ink mark,small scratch,dust particle and so on)will show as a line on your copy.So to get rid of these vertical lines on your copies you need to clean this small exposure glass.
Oct 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Small vertical lines in background
Very strange that the lines would appear on your prints aswell. Must be a faulty video adapter but I have no idea how this is getting to your paper - printer.
Get someone to look at the machine locally I don't think that we can solve this over the internet. thanks.
Sep 11, 2009 | Dell Dimension 4600 PC Desktop
1 inch lines on top and bottom of screen
Is the picture overall too small by 1 in. on top and bottom? Or is it cut off by the lines?
If it's too small, look for an adjustment labeled Vertical Height. This may only be accessible internally, it's normally a service adjustment, not a user adjustment.
Your problem is a vertical deflection issue, either an adjustment or the vertical circuit requires repair by a technician. In the latter case, electrolytic capacitors are a likely cause.
Oct 17, 2007 | Televison & Video
Acer AC713 17" CRT Monitor Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
