Question about HP LaserJet 2420 Printer
Always paper jam.
I have a HP LJ2420, the paper always gets stuck inside the printer after printing a test page. It keeps displaying an error paper jam. I always remove the paper but it's always paper jam..
Please help me how to fix this... pls...
  • alvin Jun 13, 2008
    I dont think so. Previously, I thought it was in the fuser section. But I did everything/replacement of the fuser parts to no avail.
    I saw that the paper won't get out from the printer after rolling.
    If i open the back cover, the paper will get out with the hard copy printed fine.
    There's something wrong with the top roller, i see it blocks the paper from rolling out from the printer.
  • Mashal Jun 15, 2008
    on every printing the paper jam
    how can i solve it
  • HP Master
  • 2,794 Answers
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Posted on Jun 12, 2008
  • Tim Babcock
    Tim Babcock Jun 12, 2008
    Is is jamming in the fuser section?
  • Tim Babcock
    Tim Babcock Jun 13, 2008
    Unless the fuser roller isn't seating in there properly it could be causing a problem.
    Should have a technician take a look at it.
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Cannot clear CARRIAGE JAM on my c5180
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Sep 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
P2015 paper jam light always on
Pull open the back cover and shine a flashlight inside.
Feb 03, 2009 | HP LaserJet P2015dn Printer
Paper Jam
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | HP LaserJet 4mv Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2420 Printer Logo
508 people viewed this question
Seeker5211
Seeker5211
