Indesit washing machine will not drain and carry on with full cycle
I have an indesit WIA101 model and in the last day or so it has stopped just whiklst washing and the led lights come on. I have three lights for wash, then rinse and finally spin. Now the ones which are lighting up are the wash and spin and the door lock led is flashing continuously, but the other lihts flash intermitent. We have drianed it manuallly, checked the filter at the front, checked all the plumbing and come up with nothing, the machine is not even two years old and Indesit want £100 just to come out and cannot guarantee thay will solve the problem. Does anybody know thw error codes, as I am a mother of two girls my washer is vital. Thank you
  • killiecath Dec 09, 2008
    My indesit also won't drain, and has same symptoms as previous poster. Can't find solution here to the problem. Can anyone guide me please. Three kids, in here desperately need to solve this
    Where is thermistor as described above. I have identical problem with indesit washer draining as Corkie
Already posted previous comment. Thermistor measured resistance of c 30K ohms on meter - that seems OK. However one of the wires on to the thermistor plug looked faulty and came away when touched. Needed carefully soldered - it looks like a "punchable" connection eg BT phone socket but it ISNT <grin> Washer now working fine. (Had previously a broken front concrete block under warranty so drum shaking about more violently than usual due to that had obviously weakened this thermistor connection....)
Posted on Aug 23, 2008
Same problem - changed module with no result. Looks like the water temperature thermistor...
I have an indesit washing machine model WIA101 that needs draining in prep for disposal and i don;t know what to do
front loader direct drive
drop the drain hose to the ground let gravity empty the water
can be dumped as is
no oils or asbestos in its design
Jan 22, 2017 | Indesit Washing Machines
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
WON'T SPIN,WON'T DRAIN,WON'T SHUT OFF!
is it an indesit wia101 by any chance?
Aug 19, 2013 | Washing Machines
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
Water leaks from underneath Indesit WG1130d washing machine.
I had a problem like this and it turned out to be the hose that carried the water out to the drain was overflowing the drain pipe.
Make sure the P trap in your drain line is open and clear. A plumbers snake, draino, or a high pressure nozzle on your garden hose might help to clear it.
Oct 04, 2017 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
INDESIT WIA101 INSTRUCTION MANUAL
Hi - You can download the manual from the link underlined in blue below:
WIA101
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 09, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
1,590 people viewed this question
Top Washing Machines Experts
