Question about Princeton Digital VL1716 17" LCD Monitor
Princeton Digital VL1716 17 turns on for a second and goes out
I have repalaced a lost power supply for this monitor. Now, everytime I turn monitor on, it will give a glimpse of image and go off. If I disconect the power supply input to the monitor and connect it again, It will do the same thing. Any idea of what could be causing such behavior?
Generic Power Adapter: Input 100-240VAC 50-60 Hz 40VA-60VA
Output DC 12V 3A 36W
Thank you
  • drclarealb Jul 06, 2008
    Yup, I have the same exact problem!
    CDA
  • pog7 Aug 22, 2008
    Just want to point out that 12v, 3A is below specs... I believe it needs at least 4A.
You need output to be 12v 4a
Posted on Feb 14, 2009
  • saharich Feb 14, 2009
    one more thing check your dc output on the back of the monitor to make sure its compatible because there are some that have 12v5a output.
How do I unlock the monitor, given that I have applied all the usual button pushing solutions bar 1?
If you see a picture but then it fades out after a few seconds then the issue is with the backlight power supply in your monitor, This could be a single component failure or more serious.
Mar 07, 2012 | Samsung SyncMaster P2250 22 inch LCD...
The montier turns on then turns right off
Hi!
When a monitor display image for a second and then goes to black screen... there are possible reasons why this problem occur..
1. You need to check if the high voltage ballast transformer of your backlight inverter is about to be burned... the transformer is overheating..that's why you experience the monitor working for a couple of seconds and then it will shut off until the transformer cool down again and then it will be ready to work again...
2. Check also the backlight inverter if it is busted...the backlight inverter is the light source responsible for the image display you seen on your screen. If this are busted then all that you will be seeing is black screen
3. You need to check the power supply section for possible loose connections and possible blown and bad capacitors..
the ballast transformer has direct effect on power supply section.. when there is overheating transformer,,, the supply current from the power supply section becomes unstable.. and will not be able to supply the remaining good working ballast transformer.
In case you do not know, the ballast transformer generates high voltage for the backlight inverter to work....
Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....
Much appreciated if you rate this help...thanks...
May 25, 2010 | HP f2105 21" LCD Monitor
I have a 17 inch princeton monitor and the screen goes off frequently. each time it was every 15 mintuires now it goes off every 4 to 5 mintures. i turn if off and back on and it works. help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | Princeton Digital VL1716 17" LCD Monitor
Samsung SyncMaster 730B LCD monitor isn't backlit at all
Most failure in LCD monitors are due to cheaply made caps being use. If you are going to DIY repair, please read below, or if you are going to have it fixed then at least you will know if you are being ripoff or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 22, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor blinking on and off. I had this problem once before with this same monitor. When you went from the screensaver to the desktop it would flicker back and forth between the image and the black. After...
Please read below if you decide to DIY:
Apr 19, 2010 | Samsung 206BW Monitor
Computer monitor is dark -- no desktop
Try to connect your computer to another monitor and reinstall your graphics card. In parallel, try to connect your monitor to another computer and check if it is working properly.
You'll know for sure who the culprit is.
Apr 17, 2010 | Computers & Internet
My Princeton monitor will show the normal screen for about one second when I push the power button, but then immediately goes off (screen is black). If I push the power button off, and then back on it does...
It more likely to have the same failure as other Princeton monitors here.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 11, 2010 | Princeton Digital VL1916 19" LCD Monitor
Hello.Ihave a princeton vl1919 monitor.The problem is when you press the power button the light comes on for about a few seconds then goes out then you hear a tic tic ticing noise can i try and replace the...
Try looking for bad caps first, see example of failed PRINCETON monitors because of bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
The ticking sound is from power supply turning on and off.
Feb 23, 2010 | Princeton Digital VL1919 19" Monitor
Princeton Digital VL1716 17" LCD Monitor Logo
304 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
