When i cut on my machine a black screen comes on sayin cannot boot insert cd and press enter
    Sergeant:
  • 186 Answers
Could be your hard drive. Make sure all connections are good. You should have a 2 little lights on the front of system case, one is your hard drive activity light, it should be red. See when you turn it on if it blinks. Take the side of the case and listen if the hard drive is spinning when you start the computer up.
Posted on Nov 02, 2010
    Scholar:
  • 77 Answers
This issue is due to no boot device found.
Please check your hard drive is inserted properly and it is detected. If detected please reinstall OS and try to boot.
To check:
1.Power ON the system and press delete key.
2. It will get you into BIOS settings.
3. Try to find out IDE/ SATA disk connected. (IDE/ SATA depends on your Hard Drive)
4. If it shows up your hard drive name(Eg: Samsung XXGB/Segate XXGB), then it is detected properly.
5. Save and exit the setting.
6. Insert bootable OS CD and start installing Operating System.
Tip
Windows computer not booting
Windows starts with a black screen .NTLDR NOT FOUND. insert the Windows CD provided by the company or get any Windows XP(home /professional) CD. Insert in the CD drive and restart the computer by pressing enter key on the keyboard. look at the bottom of the screen, it might ask to press F3 , F8 or some F(function)key to select boot option/menu. press the key  wait for the computer to copy the files, on the blue screen it will ask U to press "R" to repair ,press the "r" button on the keyboard.
wait for some time  A black screen will appear press number "1" on the keyboard then hit enter, it will ask U for the Administrator password , put the login password that U use to login the computer ( if there is no password  just press enter key)and press enter button  now u will see "c:\.........your name  type :       map            (press enter) U will see the drive map ,look for the cd/dvd drive  ... now type the letter  c,d,e,or f which ever is beside the cd/dvd drive and press collon example: if the cd/dvd drive is "d" d:                          (press enter)
now type in  cd i386                  (press enter)
again type in copy ntldr c:          (press enter)
it will give a message  1 file copied
now remove the CD from the drive and  type in exit or simply restart the computer
**********congrats U r issue is resolved enjoy***********
on Mar 28, 2010 | Computers & Internet
I need to instal - raid driver-
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configure as boot from cdrom.
3. restart machine Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floppy insert when winxp setup asking F6 for additional driver.
Jun 17, 2011 | ASUS P5RD1-VM Motherboard
How to format my computer
insert operating software DVD in your DVD drive
restart your Pc
press Del key (.)
select boot menu
select 1st boot device
black screen appears with "CD/DVD"
at that time press enter
screen appears with :DVD CD Boot...."
at that time select enter
software installation
custom install
Jun 05, 2011 | Fujitsu Siemens SCENIC P300 PC Desktop
My notebook wont even turn on completely with out it needing the missing or corrupt file. what do i do?
I assume you have XP OS, if so insert your XP cd in the rom, restart your pc and press F2 to enter bios setup, go to boot devices and select cd rom as 1st boot device, save and exit changes, the pc will boot and when prompt, start from cd, press enter, it will check the previous installed version and actually load windows, after loading it will give you a few options, use up and down arrows to select the option "press R to repair" enter on that option, when the dos screen (black screen) appears you will have the option to choose the volume that needs to be repaired (normally drive C) and that is option 1, press 1 and enter, now you will get C:/ or the system may ask you for a password (i hope you know that password) if not try to only enter, if that is accepted the C:/ will appear and then enter the following command, chkdsk /r and enter, make sure you insert the space after chkdsk and then press enter, this command will try to fix the missing file, hope that works for you
Dec 12, 2010 | Microsoft Windows XP Home Edition
When turning on my acer aspire desktop a black screen comes up with the following and wont start up: Verifying DMI Pool Data...... Update Success Boot From CD: DISK BOOT FAILURE INSERT SYSTEM DISK AND...
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Aug 21, 2010 | Acer Aspire™ T180 PC Desktop
When i insert win xp cd in the driver then nothing happens and it then i press F10 which takes me to BIOS....but after that i just cant do anything..pls help me in step wise manner how should i install...
Make first boot device as your CD ROM by entering in to the BIOS -- > Boot Device Priority. To enter into BIOS either try F2, DEL, F10. then after insert the CD in to the drive and then you can notice this on a black screen " Press any key to boot from the CD" then press Enter or any key and then follow the instructions as suggested on the Setup of Windows XP . Now you can format your laptop.
Oct 21, 2009 | Compaq Presario C700T Notebook
System will not boot after installing lite on dvd burner
If you have an external drive connected to your computer, check in CMOS or BIOS settings. Your hard drive should always be at the first list of bootable devices.
If you still receive the same boot up problem, try to boot with your Windows installation CD. Go to Recovery Console and in the command prompt, type:
fixboot (then press enter)
fixmbr (then press enter)
bootcfg /rebuild (then press enter)
Jul 23, 2009 | Lite On iHAS324 DVD-RAM Burner
I have a TravelMate 8204WLMi. I want it boot off CD - but cannot enter bios. At the Acer screen I press F2 , it goes to a blank screen with a flashing cursor. I wanted to reload - so eventually I...
the will be some info on how to enter the bois when you 1st boot the computer and sometime it on the screen for a few seconds
IT IS GOING TO BE AN '"F" KEY AND A NUMBER LIKE F1, F10-F12
OR HOLD ESC KEY WHEN YOU BOOT UP THE SYSTEM.
OLDER MACHINES CTRL-ALT-ESC ALL AT THE SAME TIME.
COMPAQ IS SOFTWARE DRIVEN.
YOU MAY HAVE TO CALL THE VENDER AND ASK AND SEE IF YOU CAN GET THE INFORMATION FROM TECHNICAIL SUPPORT PERSONNEL
ROD
Feb 06, 2009 | Acer TravelMate 8204WLMi Notebook
Windows xp instalation
use bootable original XP CD ROM ,
First : Insert CD in to drive
2-Go to BIOS change the bootable priority as boot from CD
3-Enter serial number when asked
4-give necessary answer
After 20 minitus it complete.
Nov 26, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
