Question about Panasonic KX-TG1033S Cordless Phone
How do you adjust time settings? - Panasonic KX-TG1033S Cordless Phone
    President:
  • 1,118 Answers
Download its user manual from this location, and search for 'Date and Time', on page #15.
Hope you are able to sort your problems out soon.
Regards, Carlos
Posted on Nov 02, 2010
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
What is the timing setting?
The timing setting is a mechanical adjustment that synchronizes the position of the piston in the cylinder to the firing of the spark-plugs to produce combustion in a fuel burning engine. Most modern vehicles use sensors and a computer to control the actual timing for each firing of each cylinder. This allows the computer make adjustments to the actual time the spark plug in each cylinder fires and for how long to achieve maximum efficiency and fuel mileage. Even though the computer can make adjustments the engine still needs to be set up to a certain trimming spec so the computer can do only the fine adjustments as needed. Most engines require this timing settling adjustment to be done with the engine running BUT WITHOUT the computer adjusting the timing automatically. To do that the mechanic will follow a procedure that puts the computer in a OPEN condition causing it to only operate the engine in default settings and not make any adjustment based on sensor input. This allows the BASE timing to be set manually. After, the computer is returned to it's active CLOSED LOOP status for future driving.
Mar 19, 2016 | Cars & Trucks
How to set date/time on slick mp3 4gb player
go to settings/date and time/adjust date (or time) Month is highlighted....use left/right to adjust month, hold down menu until it highlights date, adjust date......
Jul 16, 2012 | Audio Players & Recorders
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
Time is six minutes late
Manual Time Adjustments
Some people like to set their clocks 5 to 10 minutes fast to make sure that they will alwaysbeontime.EventhoughtheSmartSet® setsthetimebyitself,youstillhave the option of adjusting the time manually if you wish.
To manually adjust the time display depress and hold the TIME button, and press either the SET (Up) or SET (Down) buttons to adjust the time display ahead or back as desired.
Each press of the SET (Up) or SET (Down) buttons will change the display by one minute.
If you hold the SET (Up) or SET (Down) buttons the display will continue to change. The display will change slowly at first, one minute at a time.
But if you continue holding the SET (Up) or SET (Down) buttons the display will change rapidly.
Note:If you manually adjust the time, your new setting is entered into the SmartSet® memory. If the power is interrupted, the display will return to your new setting, not the original setting, when the power is restored.
Sep 23, 2010 | Emerson Smartset Clock Radio
Need instructions for t436b night light
Here is a link to the manual.
http://www.timexaudio.com/pdf/T436_IB_(new)_v3b40949_96.pdf
From the manual here is how to set the time.
2. Press and hold the Time Set Button until the time display blinks.
3. Press the << or >> Button to adjust to the correct time. Press and hold the button for faster forward or backward
adjustment.
4. Remember to set the correct AM or PM. The PM Indicator is located on the upper right side of the display;
there is no AM indicator
5. Press the Time Set Button again. The year display will blink.
6. Press the << or >> Button to adjust to the correct year. Press and hold the button for faster forward or backward
adjustment.
7. Press the Time Set Button again. The date display will blink.
8. Press the << or >> Button to adjust to the correct date. Press and hold the button for faster forward or backward
adjustment
9. Press the Time Set Button again or wait for about 10 seconds to exit the time setting process. Two beeps
will confirm time setting mode is complete.
Sep 08, 2009 | Timex T311T Clock Radio
How to set time on an alpine CDM 9823 car stero
Hi, I got this from my CDM 9832 owners manual.
Setting Time
1 In the Clock priority mode, press and hold the
DISP button for at least 3 seconds while the
time is displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours
while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder.
4 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking. The time is
automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder.
Aug 09, 2009 | Alpine Car Audio & Video
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Tyring to adjust the clock
According to the users manual, which is here;
http://vault.alpine-usa.com/products/documents/OM_CDA-7894.PDF
1) In Clock Priority Mode, press and hold the CLK button for at least 3 seconds while the time is displayed. Time indication will blink.
2) Turn the Rotary Encoder to adjust the hours while the time indication is blinking.
3) When the hour has been adjusted, press the Rotary Encoder.
4) Turn the Rotary Encoder to adjust the minutes while the time indication is blinking. The time is automatically set 5 seconds anter the minute adjustment. The time can also be manually set by pressing the Rotary Encoder.
Best of Luck.
Oct 27, 2007 | Alpine CDA-7894 CD Player
Panasonic KX-TG1033S Cordless Phone Logo
63 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
