Question about Whirlpool GAFZ21 Bottom Freezer Refrigerator
Noisey Gladiator Freezerator - Coming from top section
Our Gladiator Freezerator is about 2 years old and has been working well until yesterday. The top section (set to the refrigerator setting) was inadvertantly left open overnight. Once I discovered this I also noticed that the fan box was making a loud noise - like it is working extra hard and/or vibrating. It was also covered with ice (probably from accumulated condensation while the door was open). I cleaned up the ice and closed the door. The top unit cooled back down but it is still making the noise. Any ideas what might be causing it?
5 Suggested Answers
guly
  • 67 Answers
SOURCE: Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Posted on Sep 24, 2007
SOURCE: Ice & water dripping in refrigerator
hi , roger here i am a maintenance tech for an apartment complex that just happens to have whirlpool appliances. the way i see it is the most likely problem you have is a clogged drain. if you push the refrigerator out where you can access the back of it you will see a plastic hose that runs from about the middle of the fridge down to the bottom and then dumps into a pan that sits on the top of the compresser. the easiest thing to do is to remove the hose from the pan and blow hard through it or hook an air nozzle from a compresser and blow through it . it should take care of it. also try to avoid turning the fridge up on its max settings. hope this helps.
Posted on Feb 13, 2008
  • 65 Answers
SOURCE: Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Posted on Feb 16, 2008
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
If the air flow on the condenser under the fridge is too low, the hot gas won't be cooled enough before it goes to the door jamb to stop condensation. Remove the plastic cover under the doors and look at the condenser (tube/wire thing underneath). If it is clogged with fluff, get a vacuum and nozzle and give it a good clean so the air can pass through. Other than that, your condenser fan may have stopped.
Posted on Mar 27, 2009
  • 18 Answers
SOURCE: Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
Posted on May 29, 2009
Gladiator freezerator loud noise
Loud noises means that the Freezerator is working like it should be. The defrost heater element is on and the noise from melting ice dropping off the coil located in the back of the refrigerator section.
Jun 01, 2014 | Gladiator Freezerator Top Freezer...
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
Compressor wont shut off
Go to "Appliance Cafe", register and under the service manual section you will find the manual for that unit.
Nov 17, 2012 | Gladiator Freezerator Top Freezer...
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Broken Wheel on Gladiator only 4 months old
Call 1-800-905-9505 to get service. Should be under warranty.
Oct 04, 2007 | Gladiator Freezerator Top Freezer...
Whirlpool GAFZ21 Bottom Freezer Refrigerator Logo
131 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
