Question about HP Compaq Presario SR2020NX PC Desktop
My computer is Compaq Presario sr2020nx. When I turn the computer off sequence is normal, but once it shows the shutdown screen, takes 3 to 20 minutes to extinguish. It always seems that the system has stalled but eventually goes out. I will appreciate your help very much
    Guru:
  • 846 Answers
What do i need to connect my Compaq Presario SR2020NX to my wireless network? ready
Hello
well, you need 2 things
1) Wireless antenna in your Presario, or lan cable.
2) internet access wifi.
3) of course, knowledge on how to connect to wifi network, with your passcode and username.
Sep 07, 2013 | HP Compaq Presario SR2020NX PC Desktop
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
For additional questions please post in a Comment.
(Top right of your page, blue Comment)
Regards,
joecoolvette
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
Windows\system32\ntoskrnl.exe filie is missing or corrupt.
need to reinstall windows cause the system files for the operating system is corrupt.
On your compaq, keep pressing F10 as you turn on the computer and that should take you into the factory restore.
If you can't get into that then you'll need an operating system cd and then download the drivers off of the compaq website: partsurfer.hp.com
Jan 11, 2010 | HP Compaq Presario SR2020NX PC Desktop
Can't connect my Compaq SR2020NX to the internet
Make sure the cat5 cable coming from the modem is going to the computer and bypass the router for now.
If the computer is able to connect to the internet then you know its a configuration issue with the router. If it still can't connect to the internet then you know its an issue with the computer, might be a driver issue with the computer at that point.
Call your Internet service provider and have them tell you the steps on how to configure your router to work with there internet service.
Nov 30, 2009 | HP Compaq Presario SR2020NX PC Desktop
Computer won't turn on, you can hear the fans turn on, and the green lights turn on, but no screen.
check your connections to the monitor and pc make sure all your connections are secure. It could be a bad video card in the pc, bad cable or bad monitor.
Oct 31, 2009 | HP Compaq Presario SR2020NX PC Desktop
Appears to be stuck in sllep mode, sr2020nx
unplug computer if necessary. Can also hold the power button in until it shuts off. Then you might want to to turn hibernation off in your power settings in your control panel.
Oct 25, 2009 | HP Compaq Presario SR2020NX PC Desktop
Error Code
All you can do is Reinstall windows. You should get the Windows Vista Installation CD with your laptop and all you have to do is put it in and restart your computer and when the message that says "Press any key to boot from CD" press a key.
If it doesn't show up, you may have to press a key like DEL or F12 to get the boot sequencer. When you first turn on the computer you should see the Compaq logo. At the bottom of the screen you should see some buttons to press to do things like BIOS and Boot Sequence. You want Boot Sequence. Once in boot sequence, select the CD-DVD and press any key when it says to.
Once in follow instructions or oyu can reply and i will tell you how to install.
Oct 06, 2008 | Compaq Computers & Internet
Open Questions:
+1(866)201-6261 AOL tech support Contact Toll-free E-mail As of 2014, the best way to contact AOL by phone is to call +1-************ between 10 a.m. and 06 p.m. Eastern time. This number provides AOL email members assistance with their accounts, connections and other technical issues, according to AOL mail Help or AOL Desktop Gold. It is also the number for password-related issues. AOL provides a separate number for customer support in Spanish ************ as well as a phone number for deaf and hard-of-hearing customers to communicate via TTY ************. AOL also offers online help through its AOL Help website for members with AOL My Benefits Plans as well as users of AOL Mail and AIM accounts. AOL is a very popular email client and such is its desktop gold version. There might be some issues with this service which can be easily solved by finding the right course of action. AOL Gold Support Number is the easiest option to work with AOL with the support of our professional technicians. Following are the common issues with AOL Desktop Gold version: 1. There is an error while downloading the AOL desktop gold. • The system is freezing during the download process. • Unable to login to your AOL account. • AOL is creating trouble while running. • AOL desktop gold icon is not working. • The application has stopped responding unexpectedly. All these are the general issues with AOL desktop gold and can be easily resolved by getting in touch with AOL Support Number. Some of the AOL issues can also be solved by applying the troubleshooting tips: • If you are facing issues while downloading the AOL desktop version, then go through the given steps: 1. Check if your system has been infected by any malware or virus and is not letting you download the app, then run the malware scan for your system. After this try resuming the download process. 2. Make sure there is enough space in the system to download the AOL desktop gold file, if not then delete the unnecessary files from your system. 3. Verify your system requirements for the requirements of the AOL desktop gold version. 4. Make sure your system is updated with the latest drivers and software. • To solve login issues with your AOL account, these things can be tried: 1. First, you need to clear your system off the junk files, caches, cookies, and temporary files. 2. Check the firewall and browser settings to resolve the login trouble. 3. Reset your web browser and check if you can now login easily. • If the AOL Desktop Gold icon is not responding, then check the network connection as well as the modem and the router. Your system should be free of all viruses and malware in order to correct this issue. AOL Desktop Gold Support Nmuber is also available to help you deal with the AOL email client. • If you are facing difficulties while opening the AOL mail, then undo the changes you have made in your system. Also, try opening AOL after disabling the add-ons as well as resolve the issues with this software. • If there is an issue while sending or receiving emails through AOL then you need to check the IMAP or SMTP settings of your account. • If you are unable to login to your AOL account, you will have to reset your password with the help of your alternate email address or mobile number or dialing AOL Password Recovery Number. You will be able to recover your password and a verification code will reset your password. For further help and support with AOL Desktop Gold and its features at the AOL Gold Support Number. We can connect you with the AOL experts who can easily resolve the general issues with AOL. You can talk about the errors you are using while using this email client. The technicians are well-qualified, certified, as well as the required knowledge support.
Mar 19, 2019 | VIA Computers & Internet
See all HP Compaq Presario SR2020NX PC Desktop Questions
HP Compaq Presario SR2020NX  PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
