Question about Dayton (4LX41) Heater
NAT GAS CONVERTED TO lp ,DAYTON MOD 3E133D - Dayton (4LX41) Heater
3 Suggested Answers
roniecon
  • 6927 Answers
SOURCE: Can the Dayton model 3e368e be converted to use
If you know a dealer or repair company,they can order orifices to change out in the unit.
Posted on Oct 17, 2009
  • 4736 Answers
SOURCE: need to convert honeywell gas vlv from lp to nat.
Is this gas log set you're trying to convert Vented or Vent-less?
Posted on Sep 12, 2011
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
I have a garland h283 i want to convert to nat gas from lp what is the orrafice diameter? I would like to drill the lp oriffice out. Also do i need new pilots?
Most gas ranges that can be converted between LP and natural gas include an orifice kit usually located by the gas connection and regulator. Some ranges cannot be converted. I doubt you will be able to find any documentation that tells you the size of the required orifices. Remember that there is an orifice for each of the surface burners as well for the oven and broiler burner(s)
Oct 31, 2013 | Hotpoint RGB745 Gas Kitchen Range
NATURAL GAS TO LP FOR ADMIRAL 6.5 #AGD4675YQ
Propane burns hotter than Nat Gas, so it needs a smaller orifice, and less combustion air. Don't do it yourself, get your LP company to come out and do it, and sign off with a sticker that they converted it, in case it ever catches on fire, you will be absolved of all litigious liablitity.
Feb 04, 2013 | Dryers
How do you change a change glo-warm sit 630 from natural gas to propane
You cannot do it. Their is no way. These come in 2 versions. Natural OR propane and they cannot be converted. The pilot is designated as a nat pilot assembly and the gas valve is designated a nat only valve. Their is no way to convert it not without costing a ton of money. You would need a LP gas valve and an LP pilot assembly. It would be better just to sell it to a nat gas user and get an LP one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | Kitchen Ranges
From natural gas to propane
Page 3 shows your conversion kit part numbers provided by PARTSTOWN
The pilot light has to be converted to LP. The burner orifices must be swapped out and the gas valve must be converted. from Nat to LP. Do your swap out and open your air shutters. Light it off and tweak the air as needed then party on!
Jul 26, 2011 | Imperial IFS40 Deep Fryer
I just had a noritz tankless hot water heater converted from LP gas to natural gas, and had the hot water heater moved outside my garage. Before the gas change over and the move, I could turn on my garage...
One thing that comes to mind right off is did they use proper size orifices when they converted? L.P. uses a much smaller size then natural gas because it runs at a much higher pressure. Just a thought but I had a water heater from the factory for a mobile home that had the nat. gas sticker on gas valve and I hooked it up in town to nat. gas supply. Unfortunately it had L.P. orifices and I was in a hurry to get to another job ,lit it turned burner on and left. Two hours later my customer called to say they didn't have enough hot water. Didn't take long to discover what the problem was and correct it. Thank god for good customers. Hope this helps you. Thanks
Nov 24, 2010 | Bosch Indoor Gas Tankless Water Heater...
Want to convert heater from natual gas to lpg are jets available for this conversion.heater model no reh210ec thankyou
Dont know if you can get orvices for that heater but almost all gas appliances can be converted for nat to lp and lp to nat,they made a spud kit which is a blank orvice that you drill out your nat gas orvice to I think a 20 drill side and install the spud in and redrill to size usally a nat-gas orvice is around 8 to 10 sizes larger then a lp.The big thing is the gas valve and if it has a built in regulator or not,some valves can be conferted to open up the regulator pressure by the spring or a block off kit and others are fixed and cant be changed,have to replace valve.most nat-gas are at 3" to7" and lp is at 10".Hope this helps you
Jul 05, 2010 | Heating & Cooling
Oct 17, 2009 | Dayton (3E386) Heater
Natural gas to lp
I have a. caloric mod rls340 with regulator. what is the procedure to switch it to lp from nat gas??
Dec 30, 2008 | Maytag MGR5770 Gas Kitchen Range
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Dayton (4LX41) Heater Logo
74 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
