Question about Canon imageRUNNER 5570 Copier
What is the reset for error code E000004-0010?
  • Canon Expert
  • 270 Answers
This is fixing error code. The E004 is heater has failed - this usually last the life of the copier. The 0010 part is that the copier was turned off without resetting the error not a problem to reset. After resetting the error, fire up the copier and write down the error as displayed if it comes back. The sub code is very important to correct the problem. Some codes mean you have to replace the fixing heater power supply or the DC Controller. This is how you reset the code: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Press copier, function ( across the top of display ), CLEAR, ERR, then OK. Turn off copier and power back up. If the error happens again you may have a major problem that a tech may have to resolve. Good Luck.
Posted on Nov 30, 2010
  • Thataya Artidthaya
    Thataya Artidthaya Sep 04, 2014
    thank you very much , it works. ^^
I have canon 6570 m
on print out margin side parmanent line
i checked Drum, dipi, corano vair
Anil Gogunda 9414684770
Posted on Sep 16, 2011
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
What does error code 000000 -0000 means
How do you reset the error codes for an LG washer? - ImFee
www.imfee.com/how-do-you-reset-the-error-codes-for-an-lg-washer.html
Reset error codes on an LG washing machine by unplugging the machine, pressing ...locked 3G phones can be unlocked with the codes "123456" or "000000.
Jul 28, 2015 | Washing Machines
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Have an error message. how do i reset it
Depends on the error code. Most codes can be reset by switching off the MAIN power switch. NOT the one up on the control panel. If the code initially resets then comes back then there is a problem that must be repaired before reset will occur. There are a few codes that must be reset using the service mode or a specific reset procedure. If you can post the error code then we can tell you what the code means and a possible solution/reset procedure.
Thanks,
Wheatland Services
Oct 12, 2010 | Konica Minolta bizhub C250 All-In-One...
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
Needs simulations steps on how to reset a E8-000 code
Hello sir; This error code have no way to reset, the ptoblem is icu or pcu main board .
Apr 27, 2009 | Sharp AR-C150 Copier
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 5570 Copier Logo
3,527 people viewed this question
old marine
old marine
