Goodman Gas Pack Unit. Model PGB048125 Control Board 1068-400 Installed 1993. ** No Heat. ** Checked breaker at box. ** Have changed thermostat, no change. ** control board LED light shows: Red: System turned off at thermostat Red: A/C turned on. Flashing Red: Heat turned on at thermostat.
  • rswanson_rjb Nov 02, 2010
    Thanks for the info. The manual says the blinking error light (red light) blinks either 1, 2, 3, 4, 5, or 6 times in a row for specific problems. Mine blinks on and off continuously in the 'heat' mode. The inducer motor never starts.
    I am wondering if it could be the control board itself, though the manual says the light should shut off if there is a board error.
    Thanks.
  • rswanson_rjb Nov 05, 2010
    Tried the listed items. It turned out to be a problem with the exhaust motor.
    Thanks.
  • 8,220 Answers
Count the number of flashes and consult your manual as to what the flashes mean. The blower access door may show the faults codes. What you probably have is a contaminated flame sensor or maybe a rollout switch tripped due to rusty burners or air restrictions in your heaters vent pipe. Or a cob web blocking the tubing between the proving switch and inducer fan. Use a dry brillo pad to clean the flame sensor. Check the reset buttons on your limits clear cobwebs out of vents clean rusty burners. This video shows a typical new fangled gas furnace in action:
This video shows how to clean that pesky flame sensor:
Having an understanding of how they work can help you duagnose any of these late model wonders.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 02, 2010
  • Dan Webster
    Dan Webster Nov 02, 2010
    Comment?
  • Dan Webster
    Their can be as many as 5 of theses on one furnace. They are on the burner under the burner on each side of the burner and in the burner smoke stack. They are called rollout switches because they monitor flames in a furnace. When ever air restrictions block the vent the heat builds rapidly. You must correct the problem and then reset the switch. Look for rusty burners, cobwebs, bird nest, wasps nests, etc.
Goodman HP Model ARUF18241BA locked on Strip Heat, thermostat has no control, outside unit off. What Circuit Board is corrupt?
Sounds like either a stuck relay or stuck contactor. Not a difficult fix if you have right part. Turn power off and locate how high voltage gets to the heat strip. If there is a black box on a circuit board than it would be that whole piece.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 19, 2016 | Goodman Heating & Cooling
What would keep fan from coming on if unit lights off. fan works if manually ingaged at relay.
Flame sensor dirty or out of position, , check pressure switch .
loose connections to fan . rollout switch not working .
Oct 30, 2016 | Goodman Heating & Cooling
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
We have a goodman unit that is both a/c and heat model #PGB048125-1 how do I light the pilot?
if you have a newer high efficiency furnace there is no pilot light. They are all electronic ignition
Oct 06, 2014 | Goodman Heating & Cooling
Where is fuse for 5 ton goodman package unit heat pump
Im assuming you mean the low voltage fuse? In that case its located on the circuit board inside the electrical panel on the unit. If looking for the high voltage fuse (breaker) you should have a disconnect outside protected by a breaker inside at the electric service panel (breaker box).
Travis--
Mar 25, 2014 | Goodman Heating & Cooling
Goodman Model CPLE24-1C - Two Units. One unit works fine, second outside unit will not engage.
It sounds like the run capacitor(silver can in control box) has failed if your comfortable around electrical you can change it; just replace it with the same rating as your other one. Make sure the power is off and write down it rating (i.e. 35+5 370 or 440 volts for a dual or 35 370 or 440 volts for a single).
Jul 08, 2012 | Goodman CPLE24-1 Air Conditioner
Goodman Model # GPG15709041AA Gas pack just
depending on the brand and if he had to recharge and pulled oil oiut of compressor it can cause comp to be load. goodman is also a lower end unit and you pay for what you get. it is a very reliable unit howvere
Aug 17, 2009 | Goodman CKL60AR60 Air Conditioner
I have a goodman air conditioner/gas pack won't come on at all
did you check the low voltage fuse, usually a blade type fuse similar to what you find in a car. That would keep the control board and everything else off. let me know what you find
Jun 13, 2009 | Heating & Cooling
Goodman GMP075-3 ignition problem
bad board,i have had several board failures on goodman
Dec 18, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
695 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
