Question about Car Audio & Video
Computer modem I cannot connect to torrent sites because my modem ports seem to be closed. I have connected without a router, just to my modem, and the problem seems to be the modem. Can you tell me how to open these ports? The modem is an ALCATEL SPEEDTOUCH HOME.
    Genius:
  • 1,665 Answers
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
How to configure router and switches
You can set up your router manually, without the
CD.
Make sure that your computer is able to go online
directly through the modem.
If your computer is able to go online through the
modem, that means the modem is working fine.
You will need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Once you set up the router, connect the switch to one of the port on the router. Suppose one end of the cable connected the switch to the port 2 on the router, then connect the other end to the port 1 on the Switch. connect your computer or other device to the switch.
Click Here for more information about the routers set up
Mar 13, 2010 | 2wire Computers & Internet
Connecting my linksys wrt160n router from my modem using the internet port i get no connection, but if I plug the modem into the ethenet port I do get a connection, why?
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 11, 2010 | Linksys WRT160N Wireless Router
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
What is the connection type for a verizon model 7500 modem? im trying to fix my u torrent stats and it asks for a connection type, 256k,128k, i have dsl highspeed so what sould i set this at?
That device is capable of working on different connection types but thats not your question. It appears your being asked by utorrent for your speed. Do a speedtest or look at your bill and find out what speed package your on OR just select 768 or greater if thats an option.
Jul 22, 2009 | Westell Wirespeed LiteLine 6000 Modem
Siemens Speedstream 4100: Enabling ports for Xbox live play
Do you have a router connected between modem and console? The speedstream itself has no port blocking. if it is a straight line between modem and console then all ports are already open, but chances are you have a router between the too, especially if you have other devices connected(computers and the like). If that is the case, then it is the router in which you need to open the ports. If you do have one, post make and model plus version number if applicable.
Jul 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Wireless Router Configuration
Double check that your modem has more than just a usb port on it. There should be a network port on it too. Simply connect a network cable for the modem to the WAN port on the router and then from the router to the computer.
I have never seen a modem with only usb on it. Let me know if this helps.
Oct 03, 2008 | NetGear DG834G Router
Need help in connecting to the internet using Dlink 704p router.....
it doesn't matter whether the other computer is set to static and the other one is set to dynamic as long as both computers are getting/using valid ip addresses.
if i got it right. 1 computer is connected to the LAN port of the router and the other computer is connected to the WAN port. if so, you need to connect both computer to the LAN ports and the WAN port of the router should be connected to the modem that you are using.
if the physical connection is correct, check how you are connecting to the internet through the modem. if you can access the internet from the modem without configuring anything, you just need to power cycle. turn off everything then turn on the modem first, wait for the lights on the modem to turn on properly before turning on the router then turn on the computers.
hope this'll help you but if not, just provide the following:
(1)ISP:
(2)brand/model of the modem:
so i can help you further.
Jun 04, 2008 | D-Link DI-704P Router
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
May 14, 2008 | Linksys Wireless-B Broadband Router Retail...
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
