Question about Kitchen Ranges
The stove door is not closing properly - Kitchen Ranges
  • 413 Answers
Usually when an oven door will not close properly, the door hinges will need replacing
Posted on Jun 13, 2008
Telefunken 5 plate gas stove with electric oven door does not close completely
contact Telefunken and ask them who repairs in your area
Oct 16, 2015 | Kitchen Ranges
The hinge on the main oven door of my heritage 900ef needs replacing. Where can i buy one from please
Well, you can try STOVES and see what they will charge, and/or try espares. Once you have the part number, google that to see if anyone else can supply.
You may want to think about replacing both hinges and the springs at the same time, to ensure the door works/closes properly. Also, check the rubber seal round the door, then tend to become brittle when at the end of their service life, so it may pay to include that with the order as well.
Apr 12, 2010 | Stoves 720EF Electric Double Oven
Eurogas oven door
If it is a drop down door, then generally speaking it is the door hinges nthat need replacing, as they are mot usually adjustable.
Hope this helps.
Jan 06, 2010 | Ovens
Door of the stove do not close completlely and door is not held but opens all the way almost to the floor
Sounds like you need to replace both the oven door hinges.
Please rate my solution.
Thanks.
Sep 08, 2009 | Ovens
The door of the stove don't close properly no tension on the door to keep it close or third of the way.
take door off hold 6/8 inch high slam hinges down on sidewalk put door back next your eyeballs and give me thumbs up
Aug 14, 2009 | Kitchen Ranges
What does F9 mean? Won't allow me to use the oven
F9 -It is a Door latch fault code
Check door latch components.The stove is not detecting a proper door close.Or else there might be some metal blocking the door from closing.It should solve itself in few hours else you might have to replace the door latch system.Good luck with the machine.Please do post comments.Also do rate the solution.Thank you in advance.
Apr 10, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My stove
Jun 12, 2008 | Stoves Ovens
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Kitchen Ranges Logo
315 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
