Question about Kohler K-16102-4-AF Revival Widespread Lavatory Faucet with Scroll Lever Ha...
How do you remove the hot and handles to fix a leak?
  • 7,733 Answers
Look to this PDF link.Is a installation manual, but it works also for your job.I cnat post it because iam unable to transfer the PDF on to the FixYa site.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 13, 2010
How to fix a Glacier Bay Bathroom Faucet/ Leonardo
Usually they have a small screw, but its hidden under a cap. Look at the handles you should see a small plastic cap sometimes colored red and blue for hot/cold. Using tip of small knife pop out the cap/plug. The screw holding the handle on is in there.
Mar 20, 2015 | Plumbing
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
Kitchen price pfister with spray that comes out of arm. Need to take off on/off lever at top to look for cause of leak. How to remove the on/off lever?
If you will look .....first thing would be a good idea to turn water cufoffs under the counter to off position....then remove handle,to do this there should be a set screw (hexagonal screw) on the bottom side of handle lever a heagonal wrench will be needed to remove handle...... Now that you have the handle off you can turn the cold side of the cutoff on or the hot side to find out which one is leaking hot or cold .......if indeed it is a washer ( rubber cup) that is leaking.......hope this helps...
Sep 05, 2011 | Price Pfister Plumbing
Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
I have a whining problem when the faucet is filling the tub. It appears only to be the cold water or with warm water. If we run scalding hot the noise goes away..
You have a feed back sound from the faucet cartridge. I hope when you turn the faucet off that there is no leak. If there is a leak then your cartridge is misalined. It will eventually leak and that is an easy fix.
Turn off the main water coming into the house
Remove the cap and handle of the faucet
There is a retaining pin on top, first by using a pointed instrument remove the retainer and it looks like an upside down U
Remove the cartridge and replace with a new.
Insert the new cartridge the same way you removed the old one
Install everything on reverse order.
Good Luck
Jan 07, 2011 | Delta & Single Handle Shower Faucet
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
Leaking hotwater from the tap
You have two options. You can either replace the faucets- which is much easier for a novice, or you can rebuild them. As far as removing the handles, double check and make sure there is no set screw. If there is not, then the handles should come off. You may have to gently rock each one from side to side. Once you get the handles off, you should see where the valve unscrews. Now would be a good time to turn off the main water going to the tub. Once that is done carefully unscrew the valves and remove them. Take this to Lowes or Home Depot and you should be able to find repacking kits. They usually have full installation instructions included.
Sep 27, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Leaking hot water from delta single handle facuet
I have to assume you've unscrewed the face plate, not removed it, because you can't do that without taking the handle off. Delta handle usually come off by unscrewing an allen (set) screw just under the handle itself. Sometimes these are covered by a plastic plug.
Occasionally, even after you've completely removed the set screw, the handle still won't come off. Wiggling and pulling for a few minutes will generally get it off. If not, then a hacksaw, new handle and new cartridge are the answer.
If the allen screw is stripped and that's why it won't ome off, see above.
Good Luck.
Aug 26, 2009 | Delta & Single Handle Shower Faucet
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Kohler K-16102-4-AF Revival Widespread Lavatory Faucet with Scroll Lever Ha... Logo
145 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
