Question about Alpine CDA-9830 CD Player
Help installing a stereo
I need help installing a stereo into my car the model number is cda 9830 and i nedd to know how to install with a diagram on were the wires go and how to hook them up thanx for your time get back to me asap please
Want to install an apline stereo into a freightliner columbia
Just follow the Aftermarket Wiring Diagram and you will be fine
Apr 12, 2013 | Alpine Case Cda-7873 Cda-7875 Cda-7876...
Where can i find wire harness for cda 9830
contact alpine directly with the model number, they should have the one you need, also check
Oct 04, 2011 | Alpine CDA-9830 CD Player
Hook up an ipod to this stereo
Get the Alpine KCA 420i adapter. I've had it for about 3 years and no problems. You can install the module anywhere and run the wire for the ipod just about anywhere. You can go through all of your ipod folders on the headunit. However, you will find out quickly that it can be a pain using the Alpine headunit interface tiresome on the CDA 9830 model and others similar from a few years back. I don't know if other head units have solved this issue.
Jul 16, 2009 | Alpine CDA-9830 CD Player
Is the CDA-7892 supposed to have a backlight when off?
Hello ckabee1,
The "illumination" lead on the CDA-7892 is ORANGE and terminated with a spade lug. It should be connected to the appropriate instrument panel light lead from the vehicle wiring harness. You can download a copy of the manual here with all of the wiring color codes. If you do not know the vehicle color code, you can probably find it at Just click on "Car Stereo Wiring Diagrams" at the top and select your vehicle make, model and year.
Hope this helps.
Jul 11, 2009 | Alpine CDA-7892 CD Player
Alpine CDA-9830 off-n-on mode
check all the power connections it could be that the remote wire is hooked up to somthing falty, try hooking it up with the positive power to see if that fixes the problem, useing this method will require you to have to turn off your stereo manually. the power wire is yellow and is usually thicker and the remote or (ignition) wire is red, just wire them both together. the remote wire is usually connected to the positive end of somthing that turns on when the ignition is on like the cigarette lighter. if thats not the problem it could be that its not getting enough power ether because the power wires going to it are to thin or there isn't a good connection. check the voltage at your battery and at your stereo.
Oct 28, 2008 | Alpine CDA-9830 CD Player
Wiring diagram
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
May 21, 2008 | Car Audio & Video
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Nov 18, 2007 | Alpine CDA-9807 CD Player
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
Alpine CDA-9830 CD Player Logo
228 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
