Question about Miele Washing Machines
I have a Miele Novotronic W715 WM. It is about 9 yrs old. Has worked perfectly until today. problem is that it moves through intitial phases of wash until there is water and soap mix etc then wash seems to be stuck on a continual cycle of "just turning". Only on/off light illuminated and it is not moving through cycles. Light indicator stays on on/off only. Turning knob to "drain/ spin/ rinse" only does not activate this separate function either. it just turns with. Does not drain....etc etc
  • 32 Answers
SOURCE: Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Posted on Nov 30, 2007
jumptrout51
  • 3361 Answers
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Posted on Mar 12, 2009
  • 98 Answers
SOURCE: Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Apr 01, 2009
  • 1527 Answers
SOURCE: spin cycle not activating with simpson eziset 950.
hello any spin problems could be down to the module circuit board all the best
shaun
Posted on Aug 02, 2009
  • 82 Answers
SOURCE: Door stuck closed on a Miele Novotronic W+862!
does the machine have water in it if so the door will not open check filter
My Miele Novotronic W149 washing machine does not start,although LED "Start" is ON, LED "1200 rpm" is ON, LED "Waschen" is ON). No water pump operating, nothing at all. What may be the reason?
suggest calling a local repairman that can test it for all functions. it has to get water first, if no water enters then it can not function,further
May 30, 2018 | Miele Washing Machines
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele novotronic T640 about 9/10 yrs old tumble dryer keeps stoping and the start button flashes when it stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Miele Dryers
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
My Miele Novotronic W1918's drum is moving forward and scraping on the door glass. It is also making a clunking sound when washing.
sounds like your inner tub is broken. check your manual for the warranty. if there is no coverage left be prepaired for a hefty bill
Feb 07, 2010 | Miele Novotronic W1918A Front Load Washer
Boiling water in Miele automatic W750
Hi,after posting I had the enlightened idea to run the machine again.Gut told me it was a blip,rather than a defect.Has run 2 cycles with no problems recurring.We keep our fingers crosswise!regards henk
Jan 08, 2009 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
224 people viewed this question
Top Miele Washing Machines Experts
mpservices
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
