Question about Hyundai Electronics Computers & Internet
MONITOR SHUTS DOWN : WILL RESTART AFTER A FEW MINUTES COOL DOWN.
  • 732 Answers
Purchasin757, What type monitor? If lcd type, may have 1 cold solder joint of some component lead on the "switch-mode-power-supply / inverter ballast circuit board, that goes "open" (intermittant) after it reaches a certain unspecified temperature/time period. Unit will need to be investigated by you or electronics technician to find common problem related to all brands of CCFL back-lit LCD monitors. How old did yu say your unit is??? May be that it also need some new electrolytic filter capacitors to be installed on the SMPS/ inverter board to make it servicable for 2 to 4 more years. Lots of video clips you should investigate at YOUTUBE before you return to fixya to do a customer reply and rating of this response to your post. You will also want to do a lot of readng in the fixya profiles of "budmrtn" "12fixlouie" for more info on this (your "black screen of death" symptom) common problem that affects not hundreds, but many thousands of lcd monitors. Let us know what you will do, after you research problem. 12fixlouie
Posted on Nov 02, 2010
My kenmore dryer runs 10 minutes and shuts off and when you try to restart it it just clicks
Could be overheating and has shut down to cool off. Check lint filter and vents for unclogged conditions
Sep 13, 2017 | Kenmore Dryers
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
My 1995 Plymouth Neon will run fine as long as it's cool. But as soon as the temp outside comes up, it shuts off & will restart within a few minutes. If you do this very many times,, it just...
if car shuts off when hot outside, change thermostat and radiator pressure cap.-- heres more-car shuts off when tempurature of engine gets to normal. causes; low coolant, failing coolant temp. sensor, air in water pump. it takes 10-15 minutes to reach normal range. hope this helps! good-day!
Sep 01, 2011 | 1996 Plymouth Neon
While i am on my computer my hp w1907 monitor goes black. if i shut the monitor off and wait a few minutes it will come back on but then it only stays on for a couple minutes and goes black again.
This sounds like a power board problem. Could be failing power capacitors, which are allowing the charge to leak ( stripping the screen, not recommended) will show bulging or leaking capacitors). Or it could be an issue with the PCB. The fact it will restart once it has "cooled down" points to this.
I'm assuming you have tried the monitor on a different computer, just to eliminate the graphics card (unlikely but worth a go)
Solution..get it checked by a qualified TV repairman, it may a be a simple fix.
Jul 13, 2011 | HP w1907 LCD Monitor
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
My car will start but after about 15-20 minutes of driving, the car will completly turn off...i have to wait for the car to cool down for about 30 minutes before i can restart again and drive it.. If i...
if light on dash is on, then it sounds like a bad crank sensor. shuts off while driving down road, then will not start for about 15 minutes. heres more causes:: car shuts off when tempurature gets to normal-- low coolant, failing coolant tempurature sensor, air in water pump, failed radiator fan, it takes 10 to 15 minutes for a car to warm up. check or replace coolant temp. sensor if above is ok. have a good day !
May 04, 2011 | 1995 Geo Prizm
The unit runs Ok for a few minutes and then shuts down.
Does it do this on just battery power or with an external power source? If on battery poer, then the battery if defective.
- Jim
Jul 20, 2010 | Garmin Nuvi 660 GPS Receiver
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Shut down
check coooling fan too. or replace the heat sink.
the problem that i see in your case is overheating.
Jan 15, 2008 | Toshiba Satellite A15-S157 Notebook
Computers & Internet Logo
204 people viewed this question
Top Hyundai Electronics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Hyundai Electronics Computer and Internet Expert? Answer questions, earn points and help others
