Question about Cameras
The lcd monitor does not display
The display shows nothing in any of the modes,except the stich assit mode and does not show a display in the play back,I'v tryed the disp button,but nothing happens
  • 2 more comments
  • jandfp Jun 12, 2008
    yes i can tranfer the images to my pc,but they don't show in the play back mode on the camera
    any ideas?
    no only thru the view finder
    I see nothing in the lcd display in any mode except the stich assit mode
    Guru:
  • 1,894 Answers
But are u sure that it is able to capture images? are u able to transfer the images to your PC?
Posted on Jun 12, 2008
  • 1 more comment
  • dewan nafees ahmed Jun 12, 2008
    ok now playback option is ruled out.
    are u able to see the display while shooting the images?
    i mean in camera mode
    then i am sure there is some transistor inside the control board that is faulty.
    this is what causing the problem. this wont cost u much replacing it./
    yes its due to bad transistors.
    am sure.
    sir please change the rating sir.
    you INAPPROPRIATE rating means i gave u bad advice/
    did i give u bad advice?
Didn't show correct color in analog mode
I've had this problem before. It either the cable connectors at either end or the cable itself. Make sure the connectors are just finger tight.
Mar 08, 2014 | Dell UltraSharp 1504FP Monitor
No display powershot a75
Did you get a solution to your problem? I am experiencing the exact same thing with my A75. Still takes pictures and displays them for the 2 second preview, then back to black. And they download fine, too. But I get the same black screen in every mode except stitch assist and movie mode. Thanks.
Jun 06, 2009 | Canon PowerShot A75 Digital Camera
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
Monitor is in power safe mode
your resolution is set too high go into safe mode and turn the resolution to min and then play with it until it shows nothing push the space bar and leave the setting on that
Nov 18, 2008 | Dell E153FP 15" LCD Monitor
LCD Computer monitor
This problem may occur due to wrong driver of display card or wrong display settings.
Solution:
1- Start you computer in safe mode.
2- Remove display card driver.
3- Restart you computer.
4- Install display card driver (if it does not pick automatically).
Now it should show default settings. I hope it would solve your problem.
Aug 17, 2008 | Gateway FPD2275W LCD Monitor
My P35 S-611 not show VGA video
Check the refresh rate of the LCD, may be too high. Try at 60hz first.
Set the display to 1024x768 or 800x600 then go higher... allowing it to revert back to previous mode if nothing shows.
(some/most CRT monitors cannot display widescreen format)
Set at 60hz using a CRT (you will see flicker on CRT) - then switch to LCD
Apr 18, 2008 | Toshiba Satellite P35-S611 Notebook
Proview PRO576 error message "mode not supported" and will show nothing else
Okay, we got a fix by having another monitor hooked up to our computer and going in to display and changing the display settings to a lower setting. The screen resolution - turn it to lower - I guess somehow - the setting was too high for our monitor. Don't know how it changed itself though. Anyway, change it to a lower resolution then re-hook up your monitor and see if it works. The reslution can be pushed back up until you notice the problem again.
Mar 05, 2008 | Proview PRO576 15 in. Flat Panel LCD...
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Cameras Logo
146 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
