Question about Nintendo Wii Console
WII pointer is not working correctly
Hi, Both pointers can only do the home button or when I hit home again I can use the plus or minus to go to the left or right. I never see the pointer on the screen. I extended the original Wii bar I never tested it before. it wa "working fine "according to my customer, I bought the wireless sensor bar and have exactly the same problem
  • 2 more comments
  • ajdance4u Jul 10, 2008
    the sensor bar wont pick up my wii remote unless i hold my remote sideways or face it away from the sensor bar. while the remote is facing the sensor bar i don't get a pointer.
  • WinstonL Aug 05, 2008
    Try put the wii in an another room that is dark and and get back from at least 3 feet away.
  • Anonymous Feb 10, 2009
    OUr wii remotes wil only work when they are turned sideways to the sensor. They were working fine and then just stopped. Both at the same time.
  • Anonymous Mar 03, 2009
    same problem but with a wireless remote
Make sure the sensor lead has not been streched or eaten in two by cat or mouse like mine was
Posted on Aug 10, 2008
  • 28 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
132
Posted on Mar 22, 2009
    Problem Solver:
  • 9 Answers
Make sure that the sensor bar is clean and that there is no damage
Posted on Jun 12, 2008
I can't get the cursoe to come uop on the screen, the home button n minus n plus buttons work but thats all i can do without a cursor. I;v tried resyncing with no joy n I;v tried tapping it on th palm of...
this has happened to me before are you
sure your thing on tv is clean and the end of your remote also.........
also is sunlight hitting the screen that is what always screwed me up...
hope this all helps
Feb 17, 2011 | Nintendo Wii Console
The pointer on the screen constantly stops reacting to the wii remote movements.
Click on the link below to view how to correct the pointer on your wii screen that is not responding properly.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Apr 10, 2010 | Nintendo Wii Console
Control Pad on Wii remote fails to work
Problem fix was simple-plastic cover over unit was blocking lens of the unit. Readjusted so it didn't block and now works fine.
Dec 25, 2009 | Nintendo Wii Console
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
Our pointer on the screen, won't stay still
So you're having with your Wii pointer?
Try this (I'm using Wii japan, duh):
1. Check that the sensor bar is working (use digital camera or camera phone.)
2. In the settings, there's level for how far are you between the sensor bar and the WiiMote, 1-5 level.
Sorry I can't figure it out how to say, I'm using Wii Japan.
Hope that will help! Any questions? Feel free to ask me =]
Jul 09, 2009 | Nintendo Wii Console
Wii remote not pointing
I had that same issue what
I found out is that the wii remote's are fine
the problem is probally your sensor bar
if you can't fix you can buy a new one from nintendo for $10.00 (1-800-255-3700)
hope this helped
Jun 21, 2009 | Nintendo Wii Console
Wii sensor bar is acting up
wii snsor is very sensitive has it fell or had any cracks on it. play around woith remote more, maybe it will pick up the pointer, if not available online or in some stores.
Jan 11, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
914 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Troy Gorman
Troy Gorman
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
