Question about Refrigerators
My Whirlpool refrigerator model # 21TFA and mfg date 03/05 is leaking water from the freezer into the refrigerator. this model does not have an icemaker. How do I correct this problem?
22yooper
  • 828 Answers
SOURCE: Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
Posted on May 27, 2008
tech master
  • 120 Answers
SOURCE: ice maker leaking
yes go to sears parts center and buy the ice maker part # 4317943 thats if the ice maker is in line is leaking because the mold inside is peeling off due to the wtr being to hard repl ice maker is realy easy loosen screws remove harness and repl new one that is all you might not need all parts in box
Posted on Oct 31, 2008
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
roniecon
  • 6927 Answers
SOURCE: Viking side-by-side -- Condensation
It really sounds like the defrost timer is staying on all the time.Have the timer checked.This must be a on going problem with this brand,I am getting a lot of them.So many things could be the problem,but the defrost timer is what really stands out,the defrost timer,does just that,it defrost only a certain short period of time,or it is supposed to.That is how you get frost free.If I can help any more please ask,but have the defrost imer checked ,or replaced.
Posted on Aug 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Posted on Oct 03, 2009
I have a Whirlpool refrigerator model # ET1PHKXPQ00 ser# ER2137141, Type 21TFA, dated 05/2004. It runs fine, but I am getting water in the bottom of the refrigerator all the time now. A...
  • you need to remove the cover where the fan is mounted and you will see ice build up there is the hole but you may need to use hot water to clear the ice and clear the drain hole water should come out to the back of the refrigerator you need to remve the cover behind to see the drain line make sure to disconnect the unit before you work on it.
Mar 17, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator type 21TFA refrigerator won't cool - air vent in freezer keeps icing up
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water into crisper. Water is freezing in freezer pan. Model 21TFA.
i would say you have a pluged drain tube from the top locted behind the freezer rear panel.
Nov 27, 2010 | Whirlpool Refrigerators
My whirlpool refrigerator 21TFA is leaking water from freezer into fridge. This model does not have an ice maker.
The drain is clogged. Remove freezer plate and pour a mixture of baking soda and warm water down drain.
Nov 02, 2010 | Whirlpool Refrigerators
Hi I have a whirlpool fridg. m/n ET19RKXGN00, S/N EH1230820 with a MFG date of 03/98.It's a top freezer model and I have water dripping from the top of the fridge.almost all the time. I removed the plastic...
The last tip will help you out there...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 16, 2010 | Whirlpool Refrigerators
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
May 09, 2008 | Refrigerators
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
