Question about NEC Mitsubishi Diamond Plus 230SB (Black) 22" CRT Monitor
I have a mitsubishi diamond plus 230 monitor which runs from the DVi port in tandem with an LCD Lacie monitor from a G5 applemac. Both monitors have been fine for 2-3 years with this setup. Today, however, after some 20 minutes use the Mitsubishi screen suddenly just went blank, with the orange power light flashing. I checked the lead connections and restarted the monitor but still just a blank screen and flashing orange power light. any ideas please?
sandrew
  • 2961 Answers
SOURCE: Monitor keeps switching off
The graphics card or onboard graphics driver may not be kicking in at boot up causing the monitor to shut down, check the graphics card connector for bent pins and both connector ends. If you are able, think back to when this started and use system restore to a date before is started. Also you may have inadvertantly updated your graphics driver with one of windows generic drivers, of which may be the cause. You can also try pressing F8 on boot up and selecting 'last known good configuration' and see if that cures it.
Posted on Mar 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi diamond shield
Yes the site I work for just parted one out today they just listed it on the website today. It comes complete with lenticular screen and diamond shield. Its excellent condition It sell for 125.00 and that includes shipping and handling. heres the link.
http://servicemanuals.vstore.ca/ Its listed under mitsubishi parts.
Posted on Mar 22, 2008
SOURCE: Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Posted on Apr 05, 2009
  • 126 Answers
SOURCE: Mitsubishi diamond 55 Rear Projection - Won't turn on?
The DM module is not booting up because some capacitors inside it have dried up. A common problem with that generation Mitsubishi. The repair can be done in the home and most shops charge around $250 to $300 for the repair.
Posted on Jul 10, 2009
  • 11 Answers
SOURCE: Mitsubishi symbols, what dose each picture
Snow Flake = Cooling Sun = Heating mode Rain Drop = dehumidify Odd symbol = Air recirculation (will maintain temperature)
Posted on Aug 24, 2009
Hi I BOUGHT NEW Samsung SyncMaster P2070 20" LCD Flat Screen Monitor , AND I HAVE HP COMPAQ AND THE MONITOR NOT COMMUNICATE WITH PC
http://support.dell.com/support/edocs/video/p56135/en/connect.htmhttp://support.dell.com/support/edocs/video/p56135/en/connect.htm
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=51555&prodTypeId=329290&objectID=c01525281
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
I HAVE THE SAME QUESTION REGARDING THE acER MONITOR I just bought Is x223W LCD Monitor compaatible with IBM towers. Acer Has one extra cord Andmy Ibm tower has no home for it Please respond
well that Would be a VGA Cord(BLUE COLOUR) which u have connected the other one with the white port will be DVI port.if u want better Display connect ur LCD with DVI port.u will usally find this port on a graphic card.
May 13, 2009 | Acer 22" X223w LCD Monitor
Mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Color temperature for the monitor
I have mine on 9300K. The whites seem whiter to me rather than the yellowy tint at lower temps.
Nov 12, 2008 | Mitsubishi Diamond Plus 91 19"
Can't use DVI with monitor
You have 3 ports on your graphics card(VGA - 15 pin D-Sub x 1, DVI x 1, and S-Video x 1)Now if you want to use DVI just connect the DVI port to your monitor thats all..
Enjoy!
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
NEC Mitsubishi Diamond Plus 230SB (Black) 22" CRT Monitor Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
