Question about Samsung Televison & Video
  • 552 Answers
This may be an overheating problem.
Place a large floor fan so it will blow into the back of the tv.
If the tv stays on longer or stays on all the time after that.
If it is an over heating problem, then you may have transformer flyback that needs replacement.
Posted on Jun 12, 2008
I have cw-xc124 unit its run only 1 hour and stop the timer keeps blinking thaks..
switch off the timer operation
most chain saws do not have timers ( the catagory that you posted in) but if it is a tv, get to the on screen menu navigate to timer settings and click to off---ok then exit
Mar 11, 2016 | Garden
Troubleshooting m460g timer
you should have power across the two wires to the timer while it is running . Power needs to be on the timer for it to work. One wire should be low ohms to the ground or metal surface and the other wire should be the power wire to the timer motor. if no power on the other wire to timer follow it back and you may find an open in a door switch or temp switch. good luck
Nov 04, 2013 | Maytag Dishwashers
My model t101 keeps switching from manual off to manual on
The manual override is temporary until next tripper passes.
Trippers move the override back and forth.
Remove trippers from dial to use timer as on-off switch.
Copy following link:
Nov 02, 2013 | Intermatic & Indoor/Outdoor Rain Tight...
Honeywell thermostat ducted heater keeps switching off at randle times. It will go on in the morning at 7.15am then switch off every half hour after that.
If you take the front cover off the thermostat there should be a knob that you can adjust. Play around with that until it works normally.
Aug 10, 2011 | Honeywell Programmable Thermostat Heater
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
If you have different timer, look at link below to help identify timer.
Leviton Timers:
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Panasonic Quintrix TX-25MD3 4:3 CRT TV About 20 minutes after switching on, picture flicks to a very dark one with very vivid colours. Sometimes stays like that. Knocking on side of set sometimes brings...
Condensation on the circuits needs drying off by using the TV. There maybe also contact resistance preblems which needs vibration from the side of the TV to get it working right.
Nov 08, 2010 | Panasonic Televison & Video
AEG over B1180 Keeps switching itself off after about half an hour
if oven is in fact overhaeting then fauklt will be the thermostat
Nov 05, 2008 | AEG B1180-4 Electric Single Oven
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
