Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following ink tank cannot be recognized ???????
    Scholar:
  • 94 Answers
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If issue still present call your printer manufacturer for service.
Tirzo
Posted on Jun 12, 2008
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Where is printer cartridge located and replacement part number?
<!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8Bk Black</span><br /> <!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8M Magenta</span> <br /> <!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8Y Yellow</span> <br /> <!-- END PRODUCT IMAGE --> <span class="bold_text">CLI-8C Cyan</span> <br /><br />http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#SuppliesAndAccessories<br />
Aug 24, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon printer PIXMA IP4200 has the front light flashing and I can not reset it. When I try to print it says, the tank Magenta 8, CLI-8m is not recognized. I switch tanks just to try it, but it still...
does the cartridge is compatible to the printer?? if does gleen the pin that connect the printer and cartridge, and re install the printer driver.
Nov 08, 2009 | Computers & Internet
Can't find where the ink cartridges are on the cannon mp830 to replace
THE INK CARTRIDGES :
This multifunction printer is compatible with all of the following ink cartridges. Here is a list of these cartridges and how they you can get them:
PGI-5 Pigment Black
CLI-8Bk Black
CLI-8C Cyan
CLI-8M Magenta
CLI-8Y Yellow
All of the ink cartridges are easy to install and/or replace; all you have to do is keep the printer ON, then open the cover it will come in the position and then unlock the cartridge which allows you to remove and replace the cartridge.
These cartridges cost any where between $10 and $15 each. But if you want a good deal, I would suggest purchasing your ink supplies from Costco Wholesale as they provide good prices on packages.
Jul 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error:u043
1st step: Press and hold the Stop/reset button for 5-10 sec then release. I
f ot working then use a Qtip and moisture (not wet) it with water. Cleans the chip gently and re-insert it back and redo the 1st step.
It work for me everytime!
Nov 02, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Frequent problems with the magenta cartridge of my PIXMA MP510.
Dirty or faulty contacts in the cartridge chamber is the only logical explanation.
Remove the cart and with a cotton wool bud and a little alcohol or similar[NOT ACTETONE it melts plastic] give a gentle clean.
Oct 24, 2007 | Canon PIXMA MP510 All-In-One InkJet...
182 people viewed this question
jasbo
jasbo
