My computer froze the other day so I had to unplug it and reboot. When I did this it ran a check disk. It started back up with no problems. Then I left my desk came back and there was an error message so I unplugged it and tried to reboot. When I tried to reboot my computer gave me a boot error message and now I cannot get back past the boot selection screen everytime I try to pick an option it goes back to the same screen. Pleaes Help
  • reillyglass Nov 02, 2010
    I was able to get to the screen where you can press safe mode, restore to last time computer worked correctly, etc. But now I am not even able to get there.
    My screen says:
    Reboot and Select proper Boot Device or Insert Boot Media in Selected Boot Device and press a key.
    Mind you I do not have Boot Media,
    Any suggestions.
  • 4 Answers
You could try pressing F8 at boot up and selecting 'use last known good configuration'
Posted on Nov 02, 2010
  • Justin hagerty Nov 02, 2010
    Sounds like the harddrive isn't being found. Enter the BIOS (F2, F10 or del) at startup and check it's listed in devices and in the Boot sequence. If that fails open PC up and reseat the cables between drive and board.
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Toshiba sattelite c660 restart
Try to access the BIOS screen, as check for the hardware helth and connection status.1) Black screen shows fault in RAM check he slot settings or other RAM.
2) If device shuts down itself in 2 seconds as you said, there might be a fault with the mother board or SMPS circuit which is not at related to any quarantined file by your AV.
Regards:
Himanshu
Aug 28, 2012 | Toshiba satellite c660
Laptop makes a pinging sound when opening and then crashes
your computer cannot boot from the hard drive or cannot read the drive.the drive may be corrupted so zero-fill it.and if you think that your hard disk is in healthy condition then you can try one by changing your battery and observing the screen by pluging the laptop to the wall socket and also unplugging.do you see any difference? if yes then problem with the battery(if seen that the laptop reboots after being plugged).to the best of my knowlege,the hard drive is corrupted.
Apr 02, 2012 | Gateway M-1626 Notebook
I receive an advanced dot placement mode error when I try to print
I started receiving this error after a Windows update. After 2 days of the same issue, I realized that I rebooted my computer several times but I hadn't yet turned the printer off and on. I unplugged and plugged it back in again. It ran through a quick reboot and then I was printing fine - no need to change any software settings, roll back drivers. etc.
Dec 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Manusacture hard drive needs to be rebooted
Hello ecmtruck95,
Unplug the computer and let it sit for a couple minutes. Then plug it back in and turn it on. The computer should do a hard disk check and try to fix any disk problems.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Nov 13, 2009 | Acer Aspire 5315 Notebook
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
Computer freezes up. Only unplug power cord can I reboot the computer.
  1. Dell suggests upgrading audio drivers and flashing bios.
  2. I did both of these and problem reappeared after a while.
  3. Then I removed heatsink/fan assembly,cleaned all surfaces,applied good quality silver-loaded heatsink compound and reassembled
  4. PC has been running for more than a day with no probs so far
Feb 12, 2008 | Dell OptiPlex GX280 PC Desktop
Been frozen for about a week
You have to hit the reset button. You stick the end of a small paperclip or even the wire part from those garbage bag twist-ties into the reset button which is the hole on the bottom of the player. As you push the paperclip into hole you must hold down the PLAY button. This should put it into the Recovery screen or else it will just say "Rebuilding Library". If it goes into the Recovery screen you select CLEANUP and then YES. After it goes through cleanup which can take forever then it will will usually reboot on its own or if it goes back to recovery screen hit REBOOT after you have done CLEANUP.
Jul 28, 2007 | Creative Labs ZEN SLEEK MP3 Player
Computers & Internet Logo
56 people viewed this question
Alun Cox
k24674
