Question about Dell Computers & Internet
I have dell pharos 565 than cannot turn on or charge its less than 1 year old
5 Suggested Answers
  • 4 Answers
SOURCE: my casio ex z8 camera is less than a 1 year old,
I have had the same problem twice now and Casio has sent me 2 new batteries. The 3rd battery is now doing the same thing. My advice...don't buy this camera.
Posted on Oct 28, 2009
  • 4 Answers
SOURCE: my casio ex z8 battery keeps flashing red when i
You can jump start the battery by taking a piece of speaker wire (any wire) and contacting it to a 9-volt battery for 30-60 seconds. Make sure to contact the positive to positive and negative to negative, or you may short the battery. After jump starting it the battery should charge as normal.
Posted on Nov 02, 2009
  • 3 Answers
SOURCE: We have a Leapster 2 less than 1 year old. It
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Posted on Dec 05, 2009
kel1guy2002
  • 3740 Answers
SOURCE: my model TB46599, less than 1 year old, has no
Absolutely. What sometimes happens is that carbon will build up on the cylinder head. Then when you try and start it you get a mini backfire and it knocks the carbon loose. The carbon get mashed under one of the valves and then you end up with no compression.
Here are a couple of things you can do to try and loosen it up. (Mind you that you will have to change oil after this and probably need a new spark plug.)
1. In a well ventilated area... preferrably outside and off the grass or any vegitation area, remove the spark plug and turn the engine until the piston is all the way to the top. (TURN OFF THE FUEL SELECTOR)
2. Then dump about 3 cap fulls of oit into the cylinder head via spark plug hole. (Cap from 1 qt small mouth oil bottle)
3. Pull starter cord slowly 2 times.
4. Fill the cylinder all the way to the top of the cylinder head / spark plug hole. Keep it full for about 10 minutes. Add more gas if you have to. The goal here is to soak the overhead valve seat with raw gas for a bit.
5. After 10 minutes... YANK the starter cord with ign off knowing full well your going to make a mess.
6. Add Fresh gas to cyl head (not full this time) and YANK the cord again.
7. Keep pulling cord until vapor / gas cloud stops exiting spark plug hole.
8. Install spark plug and check compression.
Good compression... Good deal.. CHANGE THE OIL because it leaked past the pistions rings during the soaking process.
Still no compression the head will have to be removed and the vavle seats hand lapped with grinding compound.
NOTE: Before turning on the ignition switch... and attempting an engine start make sure that the unit is not soaked in gas i.e do a good clean up job.
Safety First!
Thanks for using FixYa.
Kelly
Posted on Apr 02, 2010
Dell inspiron series 5547. Error code 2000-0132 Plugged in not charging
ok ann
ever replace the battery
does the PC run with the main battery removed (snaps out)
and run on AC power.
that code means, the main battery is now END OF LIFE>
looks like its 4 year old
do you run on battery all the time,? if yes they last less long.
and abused batter can last only 1 year. (cycled deed and often)
I keep a spare at all times, so when on vacation
and this happen, no batteries sold in the store with umbrella drinks.
(jokes sorry)
Jul 21, 2018 | Dell Computers & Internet
Dell Studio 1440. New battery&adapter won't charge
You either have one of the following:
1. Bad Battery
2. Wrong adapter - yours no comprende w/ unit.
3. Cracked Jack - means you've got to get a tech to take the unit apart and replace it. $150-200
4. Goto your device manager, double click bat., then right mouse click on acpi driver and update it. Hopefully that works.
or
5. Dell needs to shoot out a bios flash fix.
Feb 16, 2012 | Dell Studio 15 Laptop
I am unable to charge my philips Norelco arcitec. It seems that the battery is gone (the product has less the 1 year). Is there a store near to Richardson TX where I can take it?
If is is less than 2 years old, it is covered by the manufacturer warranty. Call Norelco customer service for assistance at 1-800-243-3050
Aug 27, 2011 | Philips Health & Beauty
Hello, the battery on my dell vostro 1500 is fully charged, at 65% of its life and passes the dell diagnostic tool, but.. when i take out the plug the battery fails in less than 5 seconds. any help is...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Dell Vostro 1500 Notebook
Hi, my granddaughter forgot her password on her hp mini and has no administrator,any thing we can do to get on?
HP support should be able to get you in using a "backdoor" or master password which over rides yours. If its less than a year old the call to Dell should be free if not you will be ask to provide your credit card for a charge. There is always an administrator assigned usally the 1st acct created on the pc after purchase.
1-877-409-3272 Dell support you will be asked for your "service tag number" which is located on the bottom of the mini Your other 2 options are reformatting the hard drive or having Microsoft support get you back in they charge as well after 90 days of purchase and will always have you call Dell first.
Aug 16, 2010 | HP 2133 Notebook PC
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Dell Inspiron flashing amber power light, not charging
I would think the batteries need replacing. That happened to my Dell Latitude CPI. The batteries won't charge past about 3%, so I got new ones and that did the trick. If this is under a year old I would contact Dell about it, if it is under a year old they should replace the batteries.
Hope this helps.
Feb 23, 2009 | Dell Dimension 8400 power supply ** FREE...
Projector keeps turn itself off
I have a Dell MP2300 with a bad power supply. Everything else is in excellent working condition. the bulb is less than a year old and has less than 500 hours on it. My asking prices are:
1. WITHOUT BULB: $50 shipping
2. WITH BULB: $150 plus shipping .
If you are interested, please contact me. I will also consider offers.
JJ
Bethesda MD - 301-588-7222
Jan 09, 2009 | Dell 2300MP Multimedia Projector
I bought an advent 7203 pc model number eaa-89 in january this year and whilst using it the other night the screen went black so i thought the battery was flat and put it on charge when i tried to switch...
dont buy advent total **** buy a 2nd hand dell better value less chance of breaking honestly i had two advents both **** one when i lifted the hard disc stopped! cheap **** now i have a shiny dell xps 1 year old warranty extend option if you want build quality night and day im also sitting with a busted 7093 yeah advent boards just burn out nasty cheap conning mothers**
Jun 21, 2008 | Computers & Internet
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
159 people viewed this question
Clive
Clive
Alun Cox
