Question about HP Pavilion dv9810US Notebook
I have an HP Pavilion DV9810us laptop and I came home from work today and it was off, but I did not turn it off. When I press the power button it seems like it is trying to start for about 1 second and then turns off. I tried to turn it on with the battery taken out and the same thing happens. The power light comes on, it sounds like the hard disk starts to spin but then stops after 1 second and the power light goes out. I have found nothing to help me on the internet.Any help would be greatly appreciated. This laptop pretty much just sits on my desk but does get moved around sometimes by my kids.
SOURCE: HP Pavilion dv 2000 Won't start up at all!
yes it is on recall and i hope they'll fix it. however, will i have to take my hardrive out and transfer my files to another computer or will they not bother with the harddrive ...
Posted on Oct 11, 2008
TechyDrood
  • 2072 Answers
SOURCE: pavilion dv7 starts up then shuts down
This sounds like you have a bad DC jack on your motherboard. This is one of the most common problems with laptops and can be caused by jarring the DC plug in or hitting it into something or simply from normal use. As a result the pins on the DC jack become loose and consequently do not provide a charge to the laptop and battery. Wiggling the plug can make the loose pins contact sometimes which would explain why it "sometimes" works when you unplug it and plug it back in. Of course if this is the case then your battery is mostly out of power and that is why it powers off after a couple seconds. This repair costs between $150-300 from a professional repair shop and I would not recommend trying it yourself unless you've had experience soldering DC jacks
Another issue could be the CPU fan/heat skin if this is failing or the CPU is overheating the laptop will power off.
Please comment if you need further assistance
Posted on Nov 21, 2009
  • 164 Answers
SOURCE: HP2510 laptop will not boot up. The power
Make sure to remove any power source from the laptop.
The most common problem can be that you may have dislodged the RAMs. Open up your laptop till you see your RAMs, in most systems RAMs compartment can be viewed without opening the system fully. When you see the ram, very carefully remove them and clean gently with a cloth and replace them cautiously make sure you don't hurt any thing.
Plug in the power sources and turn on your computer.
If this doesn't help, comment so that I can assist you further.
Posted on Apr 11, 2010
james klgr
  • 362 Answers
SOURCE: hp pavilion tx2510 powers up and turns right back off
if the ram is bad reseating it wont work has to be replaced. this is 60% CHANCE RAM IS BAD
Posted on Apr 12, 2010
Testimonial: "Even if the problem wasn't fixed he was very kind and replied promptly. This is what I call an Superb Expert."
  • 231 Answers
SOURCE: Hi my hp 6735s laptop has just started turning
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
Posted on May 27, 2010
What key to use to access BIOS?
F10 key is the easier way.
The 3 button step is F9 for boot menu, within the boot menu should be BIOS just highlight that using the arrow key and press enter using the enter key.
Jan 12, 2014 | HP Pavilion dv9810US Notebook
My pavilion dv9810us has a dark screen. I think it is the inverter. the video works great when hooked up to an external monitor. Please help.
Yes you are correct, your inverter that sits at the bottom of the screen which powers the light needs to be replaced
Jun 27, 2011 | HP Pavilion Dv9810us Entertainment...
I have a HP Pavilion dv9810us laptop. It is about 3.5 yrs old. Since last 1 yr I am noticing that the laptop is becoming extremely heated when I open any heavy resource hungry application. Once it gets too...
Hi.
If the laptop is getting very hot and shutting down then you no doubt need to clean the CPU fan and the air vents of any build up of dust that may have collected over the 3 years you've had it.
Get a can of compressed air and give short blasts through the air vents and the CPU fan grill. You should see dust shoot out of the vents when you depress the button of the can.
The CPU fan is located underneath that laptop and the air vents can be located at the sides or the back of the laptop.
If it still gets hot and shuts down after doing this then I suggest that you take the laptop to a reutable PC repair store and have them clean the inside of the laptop for you and have it serviced at the same time.
Hope this helps!!!
Regards.
May 23, 2011 | HP Pavilion dv9810US Notebook
My hp DV9810US Laptop computer displays a blank screen (black) when powering up. All led lights appear to function normally. The hdd is heard spinning and I can hear the windows jingle after a few minutes...
Your HP laptop could have a backlight problem. This could be caused by a faulty inverter or a faulty CCFL lamp. please click on this link and follow my instructions to determine the exact fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 24, 2010 | HP Pavilion dv9810US Notebook
Laptop suddenly shuts off and will not turn back
I have reviewed your problem and have the fallowing for you to aces.
First, if you have only had this unit for 5 or 6 months, get it back to HP under warranty ASAP.
I work for HP and we offer a 1 year standard warranty and a extended 1 year for Display and Graphic problems.
Please, do yourself a favor and contact customer care and they will send you a Box, per paid and will have the unit back to you within 1 working week, at no charge to you.
Hope to hear from you.
Let me know if you need anything.
Nov 05, 2009 | HP Pavilion dv9810US Notebook
HP Pavilion DV9810us laptop screen gets pink candy cane lines when not flipped to a specific position.
On hp laptops it is the ribbon cable under the quick button panel that is loose. Causing pink lines when not in the correct position.
Sep 27, 2009 | HP Pavilion dv9810US Notebook
I have HP dv9810us number lock will not come on
Reboot the laptop and hit F2 to get into the BIOS settings of the laptop. Go through the general settings and you will see a heading for number lock and the choice will be for being on or off at boot up, make sure this turned on.
Sep 25, 2009 | HP Pavilion dv9000z Notebook
I have a hp pavilion dv9810us notebook pc and forgot password. i can not get in. what do i need to do? do i have to go buy something to repair it? I have a desktop computer also...is there a way i can fix...
F8 into safe mode after cutting the computer on and boot into safe mode. click on administrator, after the system has booted up go Start>>Control Panel>>User Accounts, select your account and click on change password. you don't need the old password just leave them all blank press enter/ok/apply out of the screen and restart and there you go
Jul 05, 2009 | HP Pavilion dv9810US Notebook
HP Pavilion dv9810US Notebook Logo
197 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
