Question about Palm m515 Handheld
Palm m515 handheld
Battery how change do i
To replace battery in m500 series you have to open the unit, using Torx T5 screwdriver, then losen the latches of back cover (proper order is very important here!) You can find many tutorials, with pictures, just use google.
Posted on Jun 13, 2008
ERROR: 00001013 - calander sync.Options When I sync my palm the date book is not synced (it used to but stopped). All other data is transffered well. It is Palm m515, Windows XP Pro ERROR:...
You can use third-party synchronization software (IntelliSync, iSync, Missing Sync, etc.), contact the third-party developer for assistance.
Good luck.
Feb 05, 2011 | Palm m515 Handheld
A friend had given me his old palm m515 but i dont know how to work it i would like to print off an owner manual is that possible
I did a google search....this is what I found.
[PDF] Handbook for Palm m500 Series Handhelds File Format: PDF/Adobe Acrobat
Welcome to the Palmm500 series handheld. This handbook is ... One USB port or available serial port (serial cradle sold separately) ...
www.palm.com/us/support/handbooks/m500series_ug.pdf
Jan 28, 2011 | Palm m515 Handheld
How do I dispose of a Palm m515?
its likely the battery has just gone bad .. a new battery is not expensive but you need a small torx tool to get it open .. the m515 is still a nice machine for some, so donating it to Goodwill or other charity will do a lot of good for several people .. you can just drop it off at most places.. put everything in a box so it doesnt get seperated ..
Oct 06, 2009 | Palm m515 Handheld
How do you turn on the Palm m515
the palm m515 has a button at the top right corner .. hitting the button quickly will turn the unit on or off ... holding the button for 2 seconds will turn the display backlight on or off ... if the unit fails to start then you can do a reset .. thats like a reboot .. the top of the stylus unscrews ... that gives you a little probe that you can use to push the reset button on the back top center ... if the battery is bad you can still run the machine with the charger hooked up ..
Sep 29, 2009 | Palm m515 Handheld
If I did not charge my palm m515 will it still work? I just got a Palm m515 and I did not charge it for 24 hours before syncing it to the computer. It works fine on the cradle, but it will not keep a...
the m515 uses a Lithium battery .. the modern version of those batteries have a built in safety feature .. once its first activated then it monitors its own voltage .. if the voltage is ever allowed to go below a certain value then it will refuse to accept a charge ... when it tells you that the battery is dead its actually well above that critical voltage .. but if you let it sit for a long time then self discharge can bring it below the critical value .. when the battery is in that forbiden region then there is a chance that it will grow copper links through its insulator .. then when you try to charge it it could get very hot .. even explode .. so thats why the safety feature .. there are ways to jump start the battery and some people do that .. but you can see there is some risk .. the battery in that palm is not hard to change and they are not expensive but you need a very small torques driver to get the case apart .. i just took my 515 to the hardware and had them match it up with the proper tool .. there are kits available also that have a new battery and the proper tools to take the m515 apart .. of course they cost more..
make sure you have the external charger hooked up to the cradle .. it wont charge from the USB port voltage as i recall on this model..
Sep 04, 2009 | Palm m515 Handheld
Do I need software to sync my new palm m515 with my laptop pc?
HI,
Yes you will need to install the Palm Desktop software on your computer or your laptop. Here is a link to the Palm Support site where you can download the software that you need. If you need any other help please let me know. Best wishes.
http://kb.palm.com/wps/portal/kb/na/m-series/m515/unlocked/downloads/page_en.html
Aug 09, 2009 | Palm m515 Handheld
M515 Palm Pilot
here is your manual in PDF form
if the unit was new then you would charge it for about 10 hours .. but since its not likely new then it doesnt hurt anything to just leave it on charge ... you can even operate the palm while its charging .. over night charge should be enough to get pretty close to full ... the palm internally automatically turns off the charge when the battery is full .. so you dont have to worry about over charging .. if the unit wont come on then you can do a "reset" (back at top)
Apr 01, 2009 | Palm m515 Handheld
Palm M515 general failure
You may perform full reset by pressing the reset and power button together. If issue persists you may try disconnecting the battery about 10 minutes and connect back. That procedure will erase all user data and will set the unit to the factory default
Aug 28, 2008 | Palm m515 Handheld
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
M515, re installing basic software
Hy floody, this may sound like something you already checked, but you will notice in the top right corner of palm desktop there is an drop down arrow, is it set to System? If so , set it to all. Let me know how you go.
Sep 25, 2007 | Palm m515 Handheld
Palm m515 Handheld Logo
603 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
