Question about Car Audio & Video
I have a Delco Model 16194545 auto radio with built in cassette. #! Where can I get a pigtail for hooking this up? #2 Is there a drawing of the connector that showes what pin operates what part of the radio/cassette? If I knew whitch was whitch I coukd wire it directly -- I do not wish to damage the unit. Many Thanks Gene
iadame
  • 676 Answers
SOURCE: we need the wiring diagram
Try to see if this diagram will help you out. The ground could also be just black.
Posted on Sep 12, 2011
JMuskovitz
  • 135 Answers
SOURCE: JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
Inferno77
  • 6 Answers
SOURCE: Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Posted on Jul 27, 2007
idkia_33
  • 70 Answers
SOURCE: FORD RADIO WIRING COURIER 2003
go to this site
www.autotoys.com/New_Tech/Wire_codes/wire_codes.htm
Posted on Jan 22, 2008
Richie_asg1
  • 1036 Answers
SOURCE: c.b.radio-power won't come on.(red & black wire show short!)
The fault is probably at either end. Yes, it could have been reversed, but most radios are easily protected against this.
If you are getting no lights or anything when keying mic, then there may be an inline fuse along the cable. As you are getting continuity, open the case up, and look for any evidence of heat at the components nearest the power supply - particularly the protection diodes - Black cylinrical components with a silver band.
You really need a meter or scope to go in much further, and check supply voltages between components and -ve, and downloading a copy of the circuit diagram will help this.
The other main fault is usually the output power transistor - which needs a sink for all the power getting thrown at it. If you remove the antenna, it can quickly overheat and fail.
Both components can be checked in-situ for voltage (or not) but the output can only be tested with a scope.
Of course - the "on" light could have blown, so may be functioning without indications, - but I doubt it.
Also check Mic outputs on the plug to make sure that is working. Some units won't function if this is disconnected.
Posted on Jan 08, 2009
Have delco radio head unit model #1618995. has 7 wire plug 2 white wires on end one on end has small plug where do plug it too? has power checked with meter
Hi Steve,
I'm going to need a little more information. That looks like the serial number. I can't find any info on #1618995. What kind of car did it come out of? Sounds like some kind of Chevy. Is it an aftermarket radio? Delco is a bad choice, unless your replacing your radio with an other factory radio. What kind of car are you putting it in?
Let me know if your just trying to put an aftermarket stereo in, radio kits and wiring harnesses are available for most cars. Ray
Jun 11, 2015 | Ac Delco AM-FM Radio Cassette
2000 delco Toyota radio schematic
Anonymous,
Go to
http://www.the12volt.com/
Look at the top under "Vehicle Wiring" and search for your car.
Press the tab that says "Car Stereo" and Presto, lots of good information. I hope this helps, Ray
Mar 01, 2015 | Ac Delco AM-FM Radio Cassette
My 2000 chevrolet z71 radio comes on and does not have sound i have changed the radio out with another delco radio recoded it turn it on has the same problem
If this is a BOSE system the BOSE systems have self-powered speakers. In other words, they have a small amplifier built in with the speaker system to produce the sound. They are a "bear" to diagnose and expensive. Check to see if it has the BOSE symbol on the speakers and radio...
Aug 28, 2014 | Ac Delco AM-FM Radio Cassette
How do I find the Wire diagram for Delco Stereos?
If your nice to the dealer concerned they might help you with a diagram.eg what ever make car it came out in.just a suggestion.
Aug 14, 2014 | Ac Delco AM-FM Radio Cassette
Need wiring diagram for a Dolby delco system. Radio model #16164325. Cassette player model #16156555. Amplifier model #16147075. Paulawomack29@gmail.com Thank you
Hello. I've been there before. Go to a well known autoparts store and look into a doit your self service manuall and look into the radio-audio section. Good Luck.
May 26, 2014 | Cars & Trucks
Raido hook up
what have you tried? usually the hot wires are yellow,red,blue,or orange
Apr 13, 2012 | Ac Delco AM-FM Radio Cassette
Need wiring diagram for delco car stereo model 16165893
I know how to wire it but it only show AM....it is not an FM radio?
Mar 16, 2012 | Ac Delco AM-FM Radio Cassette
Need wiring for a delco car radio model #16205015 i want to put it in a chev 1989 prizem I am putting that model in to a buddies car??
i would try getting the wireing pigtail from the local auto salvage to plug into radio then buy an 8 dollar wire adapter such as scoche wal mart and auto zone carry them problem solved for around 20 dollars
Jun 24, 2011 | Car Audio & Video
Car Audio & Video Logo
348 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
