Crt tv tv has green color around edges of images and is greater in some scenes than others. All the white patches get a green blur. Can anyone help.
  • Anonymous Jun 13, 2008
    I Have Samsung Plano newly bought TV. At the top left green color is spreading. Any problem of picture tube???...
    Scholar:
  • 146 Answers
This sound very simple. You might need to DEGOUES your tv. Try to find a small degouesing coil at a parts store. This will take 2 seconds to fix. Just plug in the coil and wave it in front of the screen, pull it away from the screen, and it is fixed.
Posted on Jun 13, 2008
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Getting red, blue and green halos around images
I had a similar problem with red halos around images on my Hitachi rear projection TV. The problem was that the red convergence chip burned out. I replaced that and that fixed the problem. I found several forum posts on similar symptoms and fixes for Sony rear projection TVs by searching for "Sony rear projection convergence problem." Likely you've already tried the auto-convergence function for your set, if it has that.
Feb 28, 2010 | Sony KP-46WT500 46" Rear Projection...
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
Picture is red
If you are running component video, make sure the blue is plugged in and in the right spot. Component video works like this: the green is a black and white image, the red and blue are cover overlays to make the image display properly. So if everything looks plugged in right, then try plugging in a composite video (Yellow) or S-video cable switching to the appropriate input, and see if the image is still red. If so, go to the set up and set the set to factory defaults, and see if that fixes the color issue, It's possible that the color settings on the TV are messed up, with the S-video plugged in go through the set up menu and see if you can correct the color issue IF THE IMAGE IS STILL RED WITH THE S-VIDEO OR COMPOSITE VIDEO, otherwise the issue is a problem with the component video cable.
Oct 01, 2009 | Philips 60P8342 60" Rear Projection...
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Vertical Tilt on Screen & Occational Blue Spot
firstly check the 1000micro farad near the ic vertical,u have to change it.
secondly for the blue green change the positor,if you dont know where it is!!!! it the near the degassing plug
Apr 20, 2008 | Sanyo DS24425 24" TV
Color problems
green overpowering makes me think you have a crt problem. or even a bad blue or red crt.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green tint on screen
Is it a green tint at some areas alone, oris the entire image having a green tint? If it is a color patch at the corner or other areas of the screen, in all likelihood it is a degaussing problem. Color patches happen when the TV is moved from one location to another, or if some magnetic source is placed close to a CTV. Did you put a radio or Tape recorder or Walkie talkie toy or any magnetic source near the TV? if yes, remove it. And the automatic Dregaussing circuits in the TV will resolve the problem in a couple of days. But if there is an overall Green tint on the picture, it signifies a problem in the Video output stages, and there is nothing you can do, but call the technician (unless you know solid state servicing?)
Aug 07, 2007 | GE 27GT619 27" TV
Green Convergence problem
O.K. This is a CRT Projection TV see http://www.tacp.toshiba.com/televisions/product.asp?model=50H82 The Manual is available from http://www.tacp.toshiba.com/tacpassets-images/models/50H82/docs/50H82_om_e.pdf , and this describes the Manual Convergence process, I doubt this will help, but it's step #1. The problem you are describing sound to me like a deflection problem. The electron beam in the green projection 'tube' (a super bright CRT) is probably not being controlled correctly. This can be caused by several things, from least likely to most :) I do not recommend that someone untrained in electronics attempt to service a CRT based television due to the potential for extreme shock or electrocution. That caveat said, here are the possibilities. #1 Physical Trauma: The TV has been shifted moved or bumped hard, and one or more of the fixed permanent magnets used to help convergence has come loose, or the CRT projection tube was damaged. I don't think these TVs use convergence magnets anymore, but it's possible. The green CRT tube failing would be more likely if all four corners were affected, but I've seen a failing CRT affect a single corner/edge before. I believe that this model has projection tubes that are separate from the colored filters, so swapping the tubes around may be possible. I do not have a service manual for this set, and this may be a hazardous operation due to high voltages. #2 Stray magnetic field: Someone dropped a magnet into the TV, and it landed close enough to the green tube to effect it only, or perhaps some other piece of equipment is effecting JUST the Green CRT (clock radio, speaker, badly designed wall wart, etc.). Removing the offending magnetic field may cure the problem. Perhaps the offending magnetic field has been removed, but it's presence is still felt. Try using the degauss function built into the TV set (I can't find one in the manual, but it may be present). You may want to try using a degaussing coil, and see if that helps the problem. Just be careful not to get the coil too close to the base of the projector tubes. #3 Deflection drive electronics: A CRT works by using an electron beam to excite fluorescent compounds on the face of the CRT. To move the electron beam about, a process called deflection is employed. Magnetic coils (the choke) are used to steer the electron beam up, down, left or right. These coils are driven by transistors, and as one fails, you will get an image that starts collapsing in the affected section. On a standard CRT TV, that would mean the entire image is affected, but a CRT projection display uses separate red, green, and blue CRT projection tubes to build the image, so you have three times the deflection, three times the possible transistor failures, and in your case, the odd result of just the green part of the image displaying incorrectly. This problem will probably require a service call, and a electronic board swap, but the problem could be the choke (the magnetic coils) on the green CRT projection tube. Swapping the green tube for another tube could prove if it's the tube or if the deflection electronics that are going out. Again, my feeling is that this is a deflection issue requiring a board swap (I doubt anyone actually does component level repair anymore) Sorry, I don't have a better answer, peace. Paul.
Jan 13, 2007 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
