Excessice Drainage I have had my portable airconditioner since 2004. It cools perfectly fine but the problem is, recently when I run it, within an hour of running there is a large puddle of water on the floor and it continues to pour ot water if I dont shut it off.
  • 552 Answers
This may be normal for your area if there is excess humidity.
Try finding the drain hose and redirect it somewhere.
If the air conditioner is working (cooling) then that would be the problem.
If not cooking well, then most likely you need to put more freon in it and also check for a leak.
This should be done by a qualified person.
Also, try unplugging it overnight and see if it helps.
You can check if there is excess ice build up on the inside.
By unplugging it, you may solve the ice buildup problem.
Posted on Jun 12, 2008
Danby 12,000 BTU Portable Air Conditioner - Doesn't Cool Enough
put a xtra fan on you to blow the cooler air around. this might help. but i think you will find it is to small to cool what your trying to cool. good luck and good day
saw
Jul 09, 2009 | Danby Portable Air Conditioner
How do i connect a drainage tub to the back of r5050 goldstar airconditioner
most small a/c threw the wall unit use evap condensate water to sling over to cool condenser but a three sided pan can be used to catch excess condensate water will have to be fabricated, use caution when mounting refrigerant tubing threw out that area.
Aug 15, 2014 | Goldstar R5050 5,000-btu Air Conditioner
2004 honda Accord fan blower on air condition runs on high continously
THAT'S PERFECTLY FINE TARA IT'S JUST ON BECAUSE THE AC PUTS A LOAD ON THE ENGINE WHEN RUNNING AND THE FAN KEEPS THE ENGINE COOL DURING THID PROCESS
Apr 02, 2014 | 2003 Oldsmobile Alero
I have no cool air! Please help!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Amana AP077R Portable Air Conditioner
Unit overheating and blowing fuses
Low gas pressur causing the unit to overwork/heat, water trap coolant service port blocked. Some machines need 1/2 liter of water pouerd into a reservoir on the rear to aid cooling the heat exchanger, if this is dry it will overheat. cheakc the filters if it has any.
Jul 28, 2009 | Goldstar GW-HD5000 Window Air Conditioner
2002 Buick LeSabre Limited. Airconditioner cools
The dual air on this car has two temp control motors that are electronic. You need to have the car scaned at a dealer to see if it has a code for the left temp feed back circuit. If so you will need to replace the temp control motor for that side.Good Luck
Apr 30, 2009 | 2002 Buick LeSabre
Refridge freezer
well check if its wiring problem.
Dec 29, 2008 | Refrigerators
Airconditioner will not cool when vehicle is idling. But does cool when vehicle is accelerating.
the compression of your compressor is getting low. there are leaky valves that is why only at high speed the compressor would work right.
is you compressor noisy? that is a sign of a bad compressor.
tnx 4 using fixya,
drcool
Sep 29, 2008 | 2004 Chevrolet TrailBlazer
NewAir AirConditioner on "Dehumidifier" Mode Only
I have a 3 ton a/c system that removes about 5-6 gallons of water from the air per day. Most portable dehumidifiers/air-conditioners rate at approx 1/2 to 3/4 of a ton. Your water output is pretty much normal.
Jun 23, 2008 | NewAir Heating & Cooling
Heating & Cooling Logo
211 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
