Question about Pioneer Audio Players & Recorders
Pioneer spec 1 and spec 2 hook up with RG 2 processor and audiosource eq 1
I need to have help on hooking up my eq with the rg 2 the amp and pre amp work, I just moved and somehow I forget how to hook up everything
Gary
  • 682 Answers
Preamp out---------to equalizer in-------------equalizer out----to amplifier in-----------amplifier out----------to loudspeakers.
Posted on Jul 23, 2008
Need to know how to connect pioneer rg1 dynamic processor
HI,
Here i have added a link with which you will be able to make connections on your pioneer rg1.
PIONEER RG 1 CONNECTION DIAGRAM
Oct 25, 2013 | Audio Players & Recorders
Sansui 8900 zdb to connect to pioneer rg2 dynamic processer then to bose 901 active equallizer. what is the proper method to connect these?
Referring to the picture and remembering that ONLY 901's can run off of any particular amplifier.
http://vintageelectronics.betamaxcollectors.com/sansuistereoreceivermodel8900zdb.html
I can't make out the label for tape copying. You want the 901 EQ to be the "TO" when 'copy' is selected. That way it's EQ will not affect your taping to the upstream deck or processor. Or in your case, you want the RG-1 to proceess the audio first, not after the 901 EQ changes it.
http://www.classicaudio.com/forsale/pio/RG1.html
In to Outs. Both the RG-1 and the 901 Active EQ have facilities for attaching other processors or tape deck(s) within their tape loops. In a pinch you could daisy-chain the RG-1 in front of the Bose 901 EQ on a single tape loop to free up the other one.
Go to Bose.com for the manual and specific pictures of the hook-up.
Sep 05, 2011 | Audio Players & Recorders
Looking to hook up an audiosource EQ100 to an a sony cass deck
Simply place it in line with the analog input. Or install it in a Tape Loop on your integrated amp/receiver and attach your tape deck to ITS tape Loop.
Ins to Outs
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
Be advised, using analog processors on digital-capable multichannel elcetronics will only work for analog 2-channel sources.
Mar 05, 2011 | AudioSource EQ-100 Home Equalizer
I want to know what type of cable wire do you need to hook up for HDTV and where you hook it up at on the TV
HD can come from two types of cables. A RF cable, normally it is a RG 6 or maybe a RG 59 coax cable. A HDMI cable is the other method of obtaining HD on your HDTV. A HDMI cable has a rectangular shape with small pins, its about 1/2 inch wide by 1/8 inch in height. The RF connector is about 1/4 in circular. A HD signal can come from a cable box or it can come from a DVD or Blue Ray player. Google these type of cables and look on your TV for the connectors.
Jun 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a SX838 Pioneer Receiver. How do I hook up a SG9500 Pioneer Equalizer to it?
The EQ should be connected between the pre-out and the Amp-in.
The pre-out goes to the EQ input.
Dan
Jan 30, 2010 | Pioneer Audio Players & Recorders
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Dec 29, 2009 | Yamaha HTR-5890 Receiver
How should i hook up a pioneer sg-9500 EQ to a pioneer SA7500 and a TX 6500 tuner and amp
check in yhe back of your amp to see if you have a pre amp power amp rca jumpers. If you do. remove these jumpers and take the pre amp out and plug it into the eq in. Then take the eq out and plug it into the power amp in. this will put your eq inbetween the pre amp and power amp. If you don't have these rca jumpers on the back of your amp, you can do the same with your tape record in and out inputs on back of amp.
Nov 13, 2009 | Audio Players & Recorders
I dont know how to hook up my equalizer to my home theaet system. Please help me out.
You need to connect the THX-44 Between your processor and power amp If you have a reciever you need to use the pre-out / post in order to loop I also suggest using ROOMEQ WIZARD to determine what frequencies to correct.
Jun 27, 2009 | AudioSource EQ-200 Home Equalizer
Hooking it up!
If the amp has PreIn PreOut connections, then thats the best way to go. Home theatre amps however, have 5 InOuts, and this makes it hard. You can use the tape loop. Hook up the rec out on amp to inputs on EQ, and output of EQ to tape in an amp, then engage the tape monitor function whilst ensuring that the rec selector has the source you wish to use the EQ for.
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
955 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
