Question about Kenmore Dryers
I have a Kenmore 90 Series dryer and the felt on the inside drum started coming off and as the clothes dried they would get caught in it so I cut the part that was hanging. How can I repair this myself?
  • Kenmore Master
  • 8,220 Answers
What you do is order the felt that goes around the tub. They ain't all the same so do not assume any felt will do. Use your model number. The part should come with high temp glue but some parts are ordered separately. What you do is remove the drum and install the new felt. Let it dry and clean up your dryer while you are at it. Use zoomspout oil on your rollers and idler and remove your lint chute, wash it out and let it dry before reinstalling.
Manual and more repair photos are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 02, 2010
Sears kenmore dryer 970-c69042-00
YOU MUCH REPLACE THE FELT / GLIDES ASSEMBLY PART # 5303937139 THAT IS FOR THE UPPER ONE,THEN YOU CAN REPLACE THE LOWER FELT AT THE SAME TIME THIS IS THE ONE THAT MARKS AND CUT YOUR CLOTHES YOU CAN ASK SEARS PARTS FOR THE NUMBER FOR THIS PART THE LOWER ONE IS ABOUT $18.00 AND THIS WILL FIX YOUR DRAWER. THEY WILL SEND INSTRUCTION SHEET WITH THE PARTS THEN YOU WILL KNOW WHERE TO LOOK FOR IT.
Jan 16, 2012 | Kenmore Washing Machines
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Clothes get caught between the drum and the dryer wall, and they tear as the drum turns
need to change the felt strips on the dryer,take the drum out and check the front and rear felt strips that the drum rides on
Nov 02, 2009 | Kenmore Dryers
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Kenmore 90 series, clothes have marks on them from getting pinched in drum.
hi. thanks for the question. the back felt is worn. allowing the clothes to slip out. i would replace the back felt, and also clean all the venting from dryer to the outside. save hydro. thanks the appliance doc
Sep 28, 2008 | Dryers
Burning smell & Soot
Thanks for the question It looks like a piece of clothing caught fire The back felt around the drum at back must be worn dismantle and vaccum out if the felt is worn badly it will allow clothes to slip through THanks for the question The appliance doc
Jul 20, 2008 | Kenmore 63942 Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
Dryers Logo
76 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
