Question about Whirlpool Duet GHW9150P Front Load Washer
WATER IS DRAINING BACK INTO WASHER
Everytime I look in my washer I have water in it. I have tried draining the water out but when I return the water is coming back in.
    President:
  • 331 Answers
Based on your description, I'd look closely at the drain hose (the big hose going out of the washer and into the wall between the water valves). If it's stuck too far into the hole there without an air gap, it'll siphon water back into your washer. To correct this, simply lift the drain hose out of the wall drain a few inches. This will allow the water to drain and NOT allow a vacuum to form. (a vacuum will "pull" water out of the drain pipe and back into the washer thereby filling it while not in use)
Posted on Jun 13, 2008
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Does not want to drain my cabrio washing machine stop draining out water
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 17, 2010 | Whirlpool WTW6400SW Cabrio Washer
I have a maytag washing machine model PAV2300AWW that is leaking water and only draining 1/2 of the rinse load. Could this be a pump motor issue?
Jan 16, 2010 | Maytag PAV2300 Top Load Washer
My washing machine isn't draining. The drainage line does not appear to be kinked. What else can I do
Jan 15, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water is not draining out after wash cycle is complete. How do i get the water to drain out?
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
FWTR445R - won't drain, won't go into high speed spin - Fix This?
Aug 31, 2009 | Frigidaire FWTR445R
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
I have a GE PDW8060GSS dishwaser. The washer does not turn on. The "anti bacterail" swith keeps blinking. There is some water standing inside the washer. Tried draining, but water keeps coming back. Not...
If after draining water comes back then you need to check the waste water system for any cloughs. Problem might even be at the dwelling drainage system as any blockages would prevent water from going out from washer. Check the waste hose, filter and pump. clean them all if needed.
Best of luck
Jul 09, 2009 | GE Profile PDW8060GSS Built-in Dishwasher
Washer not draining water
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer draining problem
I am sorry The model I was refering to was not yours... you have an OLD belt driven model there is a panel on the back (2) 5/16 screws to see the pump the best way to replace that hose if you have to is disconnet the fill lines pull the machine out from the wall and lay it on its back for easy access..
Feb 19, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
579 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
