Question about HP Office Equipment & Supplies
I have an HP Deskjet F380 All in one Printer/Scanner/copier which is about 6months old-it has always performed perfectly but at present I`m having trouble printing photos from computer.The quality of print is poor and I have replaced cartridges which are genuine HP as recommended by manufacturer.The prints were great and just suddenly the quality deteriorated.I have read the booklet and printed out a self test report which means nopthing to me.The colour bands etc seem fine except the blocks of colour over the lined grid at the end of the sequence seem to be getting feint and the grid under the yellow diagonal blocs(the last bit in the sequence are practically non existent.As I said I don`t if that means anything or what it means.When it says try cleaning print cartridges and copper contacts-what do you clean them with?
  • payne_t1 Jun 12, 2008
    Didn`t check my first comment before moving on-missed `know `out after` I don`t`- but cant correct it-I think you get gist of problem.Anne Payne
  • 871 Answers
Hey payne
here is a copy of your problem.
Issue The printer is working, but colors in the printed output are missing, faded, or dull in comparison to the original. Solution Step one: Check the paper Verify that the paper type is appropriate for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface. Step two: Check the print settings
  1. In the software application you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Verify that your printer is selected and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing Shortcuts tab.
  4. In the What do you want to do? menu, select a task. The What do you want to do? menu lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab include:
    • Print quality: If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type: If one of the options matches your paper type exactly, choose it rather than Automatic.
    • Paper size: Make sure this matches your paper.
    Additional options: click the Basics tab, then click Advanced Features . The Advanced Features window opens.
    • Ink volume: Adjusts the amount of ink printed on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the faster the printout will dry.
    • Dry time: Provides extra drying time for slow-drying printouts. Drag the slider to the left for less drying time, or to the right for more drying time. The printer will hold onto the printout until the dry time has elapsed.
Step three: Check the ink levels NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox .
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab and then click Service this device .
  2. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low
I have an HP Deskjet - 99ac57c.gif If the steps above have not resolved the issue, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
  1. Load the input tray with unused plain white paper.
  2. Press and hold the Cancel (c00636162.gif ) button and then press the Start Copy Color (c00636190.gif ) button.
  3. Release both buttons. The self-test page prints.
Step five: Note which cartridges printed which areas of the self-test page You must identify which cartridge printed which part of the self-test page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different self-test page patterns. Your self-test page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Step six: Look for defects In general, if the printer and print cartridges are working properly, the patterns (which look like grids of lines) should contain few or no missing lines. None of the colors should be missing and the colors of the blocks at the bottom of the page should match the labels below each block. Also, there should be no streaks of ink on the report. Missing lines or streaked bars If a pattern shows more than a few missing lines, or a bar is streaked, that print cartridge is not functioning properly. Figure 4: The magenta pattern shows missing lines and the bar is streaked I have an HP Deskjet - 7e505a5.gif src="http://i.fixya.net/uploads/images/7e505a5.gif" alt="7e505a5.gif" class="h_mi" />
Posted on Jun 12, 2008
  • earl norman llanera
    earl norman llanera Jun 12, 2008
    i got this one from the HP website
    if you want to check this out yourself anne payne. please do so.
    with respect to other experts...
    thanks for using fixya anne.
    here is the link anne.
    LINK
    Genius:
  • 1,142 Answers
Did you try doing a hard reset to the device
  • 3 more comments
  • Maanita Chadha
    Maanita Chadha Jun 12, 2008
    Basic copy quality troubleshooting
    If copies are being made, but the quality is not as good as it should be, refer to the information below.
    There
    are many factors that can affect copy quality and many of them are not
    related to the all-in-one. The first step is to determine if the
    all-in-one is the problem or if it is being caused by other factors.
    Review the basic print quality troubleshooting steps that are listed
    below:
    1. Check
      your paper and verify that the all-in-one has clean, white,
      inkjet-rated or multipurpose paper in it. Copier grade papers or paper
      specifically for laser printers should NOT be used. These papers are
      frequently coated and are not intended for dye-based inks.
      The
      paper packaging should also have a brightness and weight listed on it.
      The brighter and heavier the paper, the better the printout will be. HP
      recommends papers with ratings of at least 90 for brightness and 75
      g/m2 (20 pound) weight.
    2. Verify
      that the all-in-one is sitting on a firm surface that fully supports
      its weight and does not move as the all-in-one prints. If the
      all-in-one is placed on a desk or other surface that is free to move or
      shake as the all-in-one prints, the printout will not look as good as
      it should.
    3. Refilled
      or re-manufactured print cartridges will often produce inferior
      results. HP will not support any print problems that result from the
      use of re-manufactured and refilled print cartridges since their
      quality is not in HP's control. If you are using refilled or
      re-manufactured print cartridges, replace them with a new HP print
      cartridge.
    4. Print
      a self-test page from the all-in-one to verify that the all-in-one is
      working correctly. Contact HP for assistance if a self-test page will
      not print. To print a self-test page, follow the step below:
      1. Press
        Setup
      2. Press the
        left arrow
        button
        or the right arrow
        button
        until Print Report
        displays and then press
        OK
      3. Press the
        left arrow
        button
        or the right arrow
        button
        until Self-Test Report displays and then press OK
        . The self-test report prints.
        Figure 1: A self-test page from an all-in-one
        1 - Printed by the left cartridge
        2 - Printed by the right cartridge
        You
        must identify which cartridge printed each part of the diagnostic page,
        is the problem.
        However,
        diagnostic page patterns. Your diagnostic page may not look exactly
    5. Examine the self-test page.
      In
      patterns should contain few or no missing lines. None of the colors
    6. If
      the colors on the page are not correct or are missing, follow the steps
      below to clean the print cartridges. If the self test looks fine,
      proceed to step 8.
      1. Verify that there is plain white paper in the Input tray.
      2. Press
        Setup
      3. Press the
        left arrow
        button
        or right arrow
        button
        to select Tools
        and then press
        OK
      4. Press the
        left arrow
        button
        or right arrow
        button
        to select Clean Print Cartridge and then press OK
        . The unit prints a test page.
      5. Examine
        the test page. If the print quality of the page is good, stop here. If
        the print quality appears to be getting better, run the Clean Print
        Cartridge utility again.
      6. If the print quality is still poor, proceed to step 7.
    7. If
      the quality is still poor, one or more of the cartridges may be empty
      or low on ink. Follow the steps below to check the ink levels.
      1. Open
        HP Solution Center
      2. Click
        Settings
      3. Click
        Print Settings
      4. Click
        Printer Toolbox
      5. Click the
        tab.
        Figure 2: Estimated ink levels - both cartridges low
  • Maanita Chadha
      1. NOTE:
        Printer Toolbox
        from the
        Print Properties
        dialog box. In the
        Print Properties
        Features
        tab and then click
        Printer Services
        button then click the
        tab.
      2. Replace any ink cartridge that is low on ink.
    1. If
      the self test prints correctly, then the problem may be with the
      quality of the image being copied. Change the copy quality setting to
      Best and make another copy of your image. If the original image was
      created on a printer, it may not copy as well as a photograph.
  • Maanita Chadha
    ssue
    Solution
    Verify
    surface.
      File
      and then click
      Print
      Properties
    3. Click the
      Printing Shortcuts
      tab.
    4. In the
      • Print quality:
        quality.
      • Paper type:
      • Paper size:
      Basics
      tab, then click
      Advanced Features
      • Ink volume:
        printout will dry.
      • Dry time:
    NOTE:
    If
    1. Open the
      Printer Toolbox
      1. Open
        HP Solution Center
      2. Click
        Settings
      3. Click
        Print Settings
      4. Click
        Printer Toolbox
      NOTE:
      Services
      tab and then click
      Service this device
    2. Click the
      tab.
      NOTE:
      A
      cartridge might be running out of ink even if the graphic shows that
      there is ink remaining in the cartridge. Lines or streaks always appear
      in printouts when the cartridges begin to run out of ink. Replace print
      cartridges that are out of ink or low on ink
  • Maanita Chadha
    Step four: Print a self-test page
    If
    problem.
      Cancel
      ) button.
      Figure 2: HP Deskjet F300 series self-test page
    You
    is the problem.
    However,
    Figure 3: Self-test page layout
    1 - Printed by the right cartridge
    2 - Printed by the left cartridge
  • Maanita Chadha
    In
    If the self-test page shows missing lines or streaked bars,
    click here to continue troubleshooting
    Color mix
    If
    any of the colors of the bars are very different from the color dots on
    the cartridge label, the cartridge is not functioning properly.
    Figure 5: One of the bar colors is very different from the color dot on the cartridge
    If your self-test page shows colors that are very different from the colors on the cartridge label,
    Missing colors
    If any of the color patterns or bars are entirely missing, the cartridge is not functioning properly.
    NOTE:
    If
    you are printing in reserve mode, without all the cartridges installed,
    the patterns associated with the missing cartridge will also be missing.
    Figure 6: Missing colors
    1 - All colors printed - no missing colors
    2 - Yellow missing - the tri-color (left-side) cartridge is not printing properly
    If any of the patterns or bars are entirely missing,
    Ink smears
    If the self-test report shows smeared ink, you might need to clean your cartridges.
    Figure 7: Smeared ink
    Step seven: If you saw no defects
    If no defects appear on the diagnostic page, the cartridges and product are probably working correctly.
    Click here to continue troubleshooting
    (c00635950) (in English).
    Guru:
  • 1,894 Answers
Make sure there is no dust stuck near the spray holes
  • dewan nafees ahmed Jun 12, 2008
    copper contacts can be cleaned with a dilute solution that can be available at shops.
    and more over this means that u are cleaning the heads.
    if cleaning heads dont help them then heads would be faulty.
    and this can lead you to replacing the cad ridges. also.
    because in HP heads are fixed with cad ridge. while in epsons heads are a separate unit and cad ridge are separate unit.
    Genius:
  • 3,422 Answers
Try a hard reset first by unpluging all the cords for 30min
  • 1 more comment
  • Priya darshan Jun 12, 2008
    You can also put few drops of alcohol on the cotton and clean the copper contacts with it.
    If you need anymore help let me know.Please don't forget to rate or accept the solution.
    Goodluck.
    Follow these steps to check the settings for paper type and print quality.
    1. Open the Printers folder.
      • Windows 2000: Click Start , point to Settings , and then click Printers .
      • Windows XP: Click Start , click Control Panel , and then click Printers and Faxes .
      The Printers window opens.
    2. Right-click the icon for the product, and then click Printing Preferences .
    3. Click the Paper/Quality tab.
    4. In the Paper Type section, open the menu and click Plain Paper .
    5. In the Print Quality section, click Normal .
Hi. we have HP DESKJET F380 ALL IN ONE Printer-Scanner-Copier. but suddenly we cant refill the cartridge and we can't print any documents cause its always have error and we dont know what to do. also in...
I had this problem. My HP F380 also stopped accepting professionally filled cartridges too. The only solution was to start buying HP cartridges. Thankfully these are much cheaper on eBay than buying at the RRP in shops or elsewhere online.
Jan 19, 2011 | HP DeskJet F380 All-In-One Printer
It is a all in one HP F380 series printer. But I have not been able to scan with the printer. I have downloaded and installed the driver but it seems as if the scanner driver is not installed with it.
uninstall the driver with revo uninstaller & then download the full feature driver from hp.com, also make sure u check the present os version, then install it i shud be able to scan
Mar 30, 2010 | HP DeskJet F380 All-In-One Printer
When i try to copy, the printer only copies half hp deskjet F380
sir my hp deskjet f380 all-in-one printer.scanner.copier install software cd missing so other cd copy download web side address.pls informe email id;psmbalaji@yahoo.co.in. thank u sir.
Mar 13, 2010 | HP DeskJet F380 All-In-One Printer
Cant get the scanner to work
You may need the "full-featured" software installed on your computer in order for your DeskJet F380 scanner to function. If you do not, you may download this software from the HP support site: (choose your operating system)
HP DeskJet F380 Downloads
If you are having some other problem with your scanner, you will need to outline the problem in detail.
Dec 21, 2009 | HP DeskJet F380 All-In-One Printer
I have a hp deskjet 380 printer three in one i.e.printer, scanner and copier. both scanner and copier is working but not printer, why?
Dear Sir,
I want to install a hp deskjet printer (F380 All-in-one) on my lap top, but I don't have the CD anymore.
Please help me.
Thanks....Deng Wan (Msia)
Mar 24, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 - NOT SCANNING
maybe this is one of those printers that need to be connected directly to the power mains, not a power strips..check on that first
http://tinyurl.com/6qcpgy
Jul 23, 2008 | HP DeskJet F380 All-In-One Printer
Will you please help me install my HPdeskjet300 All in-oneseries
Will you please help me install my HPdeskjet300 All in one. i need ur help and i given a printing command to my printer after 1 year . the printing ink is always missing on papper. pls help me to sort out my plm. i lost my cd to install my printer.i took some software frm internet but its not working. i'm using hp deskjet f380 all-in-one-printerfrm last 1 year. pls look into my plm & do the needfull work.
with thank's
mohd anis
26/09/2008
Jun 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 Drivers
ok..it's easy to replace.
www.hp.com
enter model and operating system, and your' good to go.
btw, you got backup for that computer?
Feb 22, 2008 | HP DeskJet F380 All-In-One Printer
DESKJET F380
Please help for my HP Deskjet F380 All-in-one Printer, Copier & Scanner.
Scanner is not working with windows Vista.
Jan 08, 2008 | HP DeskJet F380 All-In-One Printer
161 people viewed this question
Ben Johnson
