Question about Samsung CLX 3160fn All-In-One Printer
WASTE TONER TANK
WHERE IS THE WASTE TONER TANK AND WHAT DO I NEED TO DO.
IT SAYS REPLACE?
I also noticed that after dumping (to the best of your ability), all the dust), it will be necessary to stick a soft swab inside and clean that small, square metal plate. I did this after first dumping then reinstalling (still getting the red light and beeping noise), and everything worked perfectly after. (No need to restart printer, nor push any additional buttons!)
Marci, Dayton OH
Posted on Dec 05, 2008
1-Open the front panel below where the paper comes out (says Samsung on it).
2- On the lefthand side is a lighter gray/tan handle. Pull it. This is the waste toner cartridge. **BE CAREFUL** this stuff goes everywhere and make a mess!
3- Dump it somewhere the dust wont offend
Posted on Jun 12, 2008
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
  • 279 Answers
SOURCE: waste toner tank
A few things can cause this.
The way the printer determines whether the waste tank is full is via 2 optical sensors, one on either side of the tank. You'll see a rounded bulge on one end of the tank - the sensors are on either side of that, when the tank is installed. Under normal operation, light passes through that and the printer reads it as meaning the tank is not full, until the tank fills far enough to fill that bulge, and thus block light and give a tank full reading.
If the tank gets too dirty, not enough light passes through and it gives false tank full readings. So the first thing to try is cleaning the tank with soap and water. Make sure that area is as clear as possible.
If that doesn't work, it has also been reported that the sensors themselves are unreliable. I am told Samsung will replace the sensor for free if it's been less than 3 years. If you call them, insist that it is the sensor that is the problem, or they will try to get you to replace the waste bin, at your expense, first: 1-800-726-7864.
Alternatively, you can remove the sensor from one side, and reattach it to the other side - putting the two sensors in contact so that they always read an empty waste tank. Do this at your own risk, however, as you will have to check the tank regularly and make sure it doesn't overflow. Doing this bypasses the sensor, so there is no longer any warning if your tank is overflowing.
Hope some of that helps you.
-Dyllan
Posted on Jan 14, 2008
SOURCE: waste toner tank full/not install keep displaying
The sensor itself weren´t dirty, but plastics in waste toner tank was bit dusty and sensor couldn´t read through it. So I modded waste toner tank a bit with a knife (took the part away which the sensor uses when reading if it is full or not). And works again beautifullu.
All I have to do know is to take care of waste toner tank manually i.e. checking it every now and then and when it becomes full I throw it away.
Posted on Feb 09, 2008
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
  • 89 Answers
SOURCE: canon IR330I: Replace waste toner catridge
Look in Service Manual. Make sure to clean neck of bottle thoroughly and sensor on copier if you can.
Posted on Jul 17, 2009
Replace the waste toner box
Please write me your copier brand name and model name.Some times when waste toner is full the tank than show massage replace the waste toner box.You should clean the waste toner than fix this massage.
Oct 20, 2013 | Copystar Ri-2530 Printer
"Replace/Install Waste Toner Tank" error message
Take aout waste toner tank (vertical handle left of cyan toner cartridge)
remove waste toner. Make shure that transparent windows are clean (light barrier). Replace aund resart printer
Oct 23, 2010 | Samsung CLX 3160fn All-In-One Printer
CLP-315 - CLP-315 Laser Printer: I have changed all the color toner but not prining...
any error indicated?
run your Smart Panel and check what is the fault that is being detected.
If all the color toner had been replace. what about the OPC & waste toner tank?
note. Please replace the waste toner tank once it is full do not reuse the same waste toner tank. as it will course the internal of the printer to be spread with waste toner and your print out will be dirty and patches.
May 16, 2010 | Samsung CLP 315 Laser Printer
I have a samsung clp500 color printer but it is not working .it show only waste tank is full/ not instaled what should i do.
The "waste tank" is located behind the front panel that has the SAMSUNG name on it. Press on the upper corners of this panel and it will open up to reveal a clear plastic tank on the right side.
This tank pulls out easily and has two holes for excess toner to flow into it.
Look at the side of the tank that has the holes. You should see a part of the tank that extends out from the tank but ends in a clear square. The waste tank sensor "looks" thru this clear plastic square to determine if the tank is full. I.e. if toner is in this area and you cannot clearly see thru both sides, the sensor will tell the printer that the tank is full and needs to be changed.
If the tank is not full, use a long cotton swab and clean out the inside of this area. Once you can see thru both sides, carefully replace the tank back into the printer and turn the printer back on.
If done properly, the error should go away and you should be able to continue printing. I have doen this and it works fine.
(Some posts have had people cut this part of the tank off and simply tape over the hole that is made with strong tape. This bypasses the sensor and would allow the printer to run again. I have not done this as I do not want the possibility of toner spilling in my office.)
Exception:
The sensor could be bad and causing the issue. If this is the case, it may be cheaper to purchase a new printer - CLP-620 ND is a duplex, networked color laser jet that is selling from frys.com for $315.
Apr 30, 2010 | Samsung CLP-500 Laser Printer
Waste Toner Tank
Please open the front cover( where the toner bottles are located). You will find a transparent "L " shaped box is the waste toner tank. You may pull it out and replace it.
Oct 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My samsungclx-3160 all in one is asking me to replace/install waster toner tank?? it wont print now whats that
The waste toner tank may be full. Please open the front cover( where the toner bottles are located).
Oct 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Red light on suggesting replacement of parts
get geniune toners and replace waste toner bin.
Jul 05, 2009 | Samsung CLP 300 Laser Printer
Replace waste toner tank message
the sensor for the waste toner cartridge is faulty or the waste toner cartridge is faulty it's self.
Apr 26, 2009 | Samsung CLP-510 Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
230 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
