Question about Belkin (F5D7230-4) Router (587009)
Wireless rooter i am trying to instal my rooter and need isp and all the other numbers
  • 106 Answers
DSL or Cable?
Posted on Jun 15, 2008
Lost password to rooter
Which password? ISP password or Router password?
If it is a router login password, then simply press Reset button which is very small usually located behind the router (near your lan port) & reconfigure your modem.
& if it is an ISP password then contact your isp & request to reser your password.
Oct 09, 2013 | Linksys WRT350N Wireless Router
Lost disc to install d-link rooter
You do not need a driver other than the NIC in your computer. if need to configure the router, connect to it through wire or wireless, then use its web-based configuration page @ 192.168.0.1 (default) via a browser.
good luck,
Majdi
Dec 16, 2011 | D-Link DIR-615 Wireless Router
How can I change wireless password?
from your rooter administration program/file.
you need to log in into ur rooter. Ussually in a browser : http://192.168.1.0 or 192.168.1.1 or 192.168.0.0 or 192.168.0.1
Login in there with ur custom username and password (you should have them on ur rooter manual. (try user: admin and password: admin it should work.)
May 02, 2011 | Computers & Internet
I need help: i cant get the my rooter to send out a wireless sign
might be the powre is not comming ............
chech out the adapter,,,,,,,,,,,,,,,,,
Jun 26, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need cd for downloading program
Assuming you are trying to install a router.... routers do not use drivers or software. CD's provided with Routers are generally used to walk you through the installation/setup process. Most Linksys routers are default accessible at 192.168.1.1 via your browser. the default username is admin and the password is usually admin. If this does not work, try resetting the router by pressing the rest button located on the back of the unit (small hole) with a paperclip. hold the button in for about 1 minute and then release it... If you are unlucky enough to have a unit with a flashing power lite, this is a dead unit and is not repairable. Look up your model for more specific instructions on www.linksys.com under the support section.
Apr 12, 2010 | Linksys Wireless-G Broadband Router
Have no setup cd with my belkin F5D7632UK4A how do I install it?
You dont need a setup CD as this is a router. you should have the manual which will explain in detail the process of installation. If you dont have the Manual as well, then provide the below details and i can help you fruther on this
Name of the ISP:
VPI / VCI value (to be collected from ISP):
Total number of Wired computer/s:
Total number of Wireless Computer/s:
Operatins System used on computers:
Feb 15, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Dlink help!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Oct 20, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
WRT400N LELA software not working
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every settings
Sep 23, 2009 | Linksys WRT400N Router
The linksys wrt54gs-uk
With a DSL modem in the US, you need to confiugre the router for PPPOE with the username/password that was provided to you by your ISP. If you can't remember the name or password, contact your ISP
May 31, 2009 | Linksys Wireless-G Broadband Router
Belkin wireless g router 2,4 ghz 802,11 g
Whats the model number of this Belkin router?
Oct 16, 2007 | D-Link DI 514 Wireless Router (DI-514)
Belkin (F5D7230-4) Router (587009) Logo
52 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
