Everything works fine with the unit...The last three days when the outside unit cycles off it makes a loud scraping noise...The model number is 4AND-036JAJ....Any help will be appreciated...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
Hello, If its making a loud squeeking/scraping noise, in my maytag that i
repaired, the problem was the waterpump. If you turn the washer on it's
side, you will see that it has a belt with three pully's on the bottom.
One pulley is connected to the waterpump and right where the pulley
meets the metal plate it's connected to, there should be a gold
coupling. This coupling sometimes comes loose and scrapes the metal
plate on spin cycle (when the pulley is spinning) which causes the
scraping/squeeking sound. If this is the case, you will see where the
coupling has scraped a groove into the metal plate. The coupling will
eventually catch while spinning and break entirely. The cheapest new water pump is $80.
I have one of these, and every so often, the fan would start making a loud clicking noise. I discovered that if I shut the fridge off for a while and left the door open to defrost it, it'd work fine again for a while before the noise came back. Apparently, some ice was building up between the metal heat-sink and the fan, causing the fan blades to scrape against the ice/frost build-up and make the "tick, tick tick" noise.
There is no compressor in the Avanti EC15W-2 mini fridge. It uses a simple Peltier junction device to transfer heat from the inside of the fridge to the outside/rear of the unit. So it should never get very loud at all, unless one of the two fans in it is acting up in some way.
Watch out! You might have a loose wheel! Check those wheel nuts. If not, a loose brake caliper, or last if not least, a bad wheel bearing. Don't drive it until you find out what the heck is wrong! Could be dangerous.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Most of the fan motors can be oiled. You will have the slide the ac forward and remove it from the case to access it. You will find yellow pull pins on each end of the motor, a lite drop or two is all that is needed.
what is the serial number
