Question about Danby DPAC8020 Air Conditioner
No instructions not sure how to work dehumidifier
Where do I find the manual for the Danby Model #DPAC8020?
Posted on Jun 30, 2008
How to recharge a dehumidifier with refrigerant
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FDF50S, is not removing moisture from the air, and you are wondering how to recharge it with refrigerant. First, I suggest making sure that there is a minimum of 12 inches clearance around your dehumidifier. This will help for the air flow. Secondly, make sure that the temperature where your appliance is located is between 41 degrees F and 96 degrees F. If it comes down to you having to recharge your dehumidifier, this is typically not a do it yourself fix, as there are no step by step instruction manuals for this. I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FDF50S Dehumidifier
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | Haier 45-Pint Dehumidifier
"Check drain" light is on
If the float switch is indicating a full drain pan, the light will be on and the compressor and fan will not run. Make sure the dehumidifier is installed level and the condensate drain is open allowing the drain pan to empty. Next check that the float is free to move up and down and the switch operates a required. Call the manufacturer at 1-800-533-7533 for parts and instructions if there is a problem wirh the float switch.
Aug 06, 2011 | Therma-Stor Santa Fe Compact Dehumidifier...
Fan not working, outlet is live, product is 6 mos old, located in an indoor swimming pool (endless swim machine) Hi E Dry 100,
If the fan does not operate with the fan switch set "on", there is a problem with the power supply, internal wiring, or the fan itself.
First make sure the dehumidifier is plugged in to a working outlet.
Next unplug the dehumidifier and remove the cabinet cover. Check the internal wiring for loose connections.
Next remove the fan and check that it is able to spin freely (by hand). If it spins freely, it should be replaced. Call the manufacturer at 1-800-533-7533 for parts and instructions.
Feb 22, 2011 | Therma-Stor Hi-E Dry 100 Dehumidifier
My small inexpensive dehumidifier stopped working, its trying to start but just can't. I have never cleaned it, lost the instructions. 1 yr. old it worked great all this time . Thanks Johnny L. PS its...
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 17, 2010 | Eva-Dry EDV1100 Petite Mini-Dehumidifier...
Running but not dehumidifying some icing on side of unit have followed instructions in manual, to no avail
Unit is low on charge...
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Aug 01, 2009 | Frigidaire FDL45P1 Dehumidifier
Delonghi de400p
same thing happend to me. I wasnt sure if it was the settings or me. I unplugged it for awhile, read thru the instructions turned it back on setting it according to the instructions and it began to work again. Not sure if it had to do with the unit being off for awhile or I entered the correct settings. Im just happy it began to run again
Jul 19, 2008 | DeLonghi DE400P Dehumidifier
Delonghi de 220 dehumidifier tasciugo
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
The above URL will allow you to download instruction manual if a PDF format.
Apr 05, 2008 | Dehumidifiers
Danby DPAC8020 Air Conditioner Logo
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
