Question about Moen & Replacement Cartridge
We are installing a new moew tub facuet and shower and need to know where it says to use copper pipe if this is required because our pipes are cpvc thank you ruth
    Genius:
  • 1,015 Answers
To the best of my knowledge it doesn't matter what type of pipe you use. Just make sure you install valve in the right position. Thanks
Posted on Nov 29, 2010
My shower head comes on all the time
two possible causes. 1- make sure the valve body is installed with with shower mark on the valve body facing up. 2 - if you used pex pipe and fittings to stub out for the tub spout this will restrict the flow sending water to the shower, '' change out pex pipe and replace with copper or galvanized pipe
Apr 06, 2014 | Globe Union Glacier Bay 8 In Double Handle...
The pipe that has shower head does not fit tightly into the facuet; I am installing a new facut with a hand shower and a shower head system
Try screwing it in opposite of normal threading. Left to tight not right to tight. Usually with anything liquid especially water connections threading is opposite.
Mar 05, 2011 | Franklin Decor Bathware Shower Rod
The plumber installed shower diverter and when the tap is running so is the shower. He did not install with copper pipes, but now says there doesn't have to be. He has thrown out the insturction and...
Copper pipe is not required for correct fucntioning of the diverter valve. Some diverter valves are not 100% shut off of tub faucet.... But it should mostly shut off. I suggest that debris may have damaged the rubber parts of the diverter, take it apart and inspect.
In my opinion PEX (which is plactic, multiple layer pipe) is much better than copper. Copper reacts with chemicals in the water, in some areas of the world....
You did not mention what BRAND, or model controls you have installed, but having the warranty sheet missing shoud not harm you getting what you need, and it cannot be a big deal, as there is little to a diverter valve...
Feb 26, 2011 | Home
When using the tub water comes out of the shower head
if the pipe feeding the tub spout is pex, cpvc or poly then it needs to be replaced with a pipe with a larger i.d. like copper or galvanized or reduce the pressure to the house.
Dec 01, 2010 | Moen Posi-Temp Single HandleTub And Shower...
We have Delta brand tub/shower fixtures, the one handle kind. The problem is that water comes out of both the tub faucet and the shower head, even though the shower is not turned on. This happens every...
You need to replace the tub diverter/spout. There are two kinds, I hope you have the kind with
an allen head set screw on the bottom side of the spout near the shower wall. These are super
easy to replace ! Loosen the set screw, twist the spout a little and it should slide off. When installing
the new spout, smear some vaseline on the copper pipe sticking out, this will help seal the new O rings in the spout.
The other kind of spout has pipe threads in it. They can be a little more tricky. I got called to a
house one time. The plastic female threads on the spout cracked when the plumber installed it.
The water ran down the inside of the wall and did damage down stairs. The leak could not be seen
until the sheet rock down stairs fell down from being soaked. You need to put some pipe dope on the threads, then tighten the spout on by hand, so as not to scratch it with a pump pliers.
I hope this helps !
Nov 03, 2010 | Delta & Single Handle Shower Faucet
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Do you have written instructions for taking out an old faucet and replacing it with the INS898D-3/09 faucet? The directions that came with are just pictures and I need more explanation.
Good for you taking on this project. The first thing I will start with, is if you are not comfortable soldering copper then I would stop and call in a plumber to install the shower. If you have soldered copper in the past and are comfortable doing so then please proceed. Give yourself 2 to 3 full days to complete the project. You will need: Plumbing permit, available from your local munucipality. It will need to be inspected after the work is completed. Solder, solder flux and propane torch Heavy suede work gloves Water Spray bottle Pipe wrench Safety Glasses Hacksaw Deburring tool for copper pipe Emery cloth Tape measure Screw driver or screw gun Mounting Screws Old blankets 5 gallon pail 1/2" Copper pipe and fittings To begin we will have to uninstall the old shower. I find it helps to take photographs of the existing system so that you can see how the new one should go back together in case you get stuck halfway through the project and cannot see how to finish it off correctly. If you can access the shower from the other side of the wall, great. If not you will need to remove the shower surround or tile on the end wall where the plumbing is. Be sure to protect the tub with an old comforter or something to keep the tub from getting scratched up during construction. Before removing the old shower be sure to locate the shut off valves and close them. Turn both hot and cold on in the shower to remove any water pressure in the lines. Disassemble all the trim pieces of the old shower including the tub spout, handles, diverter and shower head. Take measurements of the existing piping to assist you when it comes time to cut and assemble the new copper. Do not reuse any of the old fittings. They will be very difficult to solder and new ones are very cheap. You should have 2 copper risers coming out of the floor, one cold, one hot. Cut them approx 12" above the floor. Repeat the same process for the tub spout and the shower riser. With all 4 pipes cut you can now remove the brass manifold from the 2X4 blocking. Disassemble the shower flange pipe from the copper shower riser. You should now have just the cut copper risers coming out of the floor. Use the deburring tool to clean the sharp edges where you cut the risers. This will aid in soldering the new pipe in and avoid you cutting yourself on the sharp copper while you work. To be continued.
Now that everything is apart it is time to cut all the copper to proper size and mount the brass manifold on the blocking within the wall. Take a close look at the drawings on the instructions. The plastic piece that covers the brass manifold will need to be flush with the drywall so that when you install the escutcheon plate it is also flush with the drywall. Be sure to test fit all the plumbing before soldering to ensure. begin by soldering the fittings that will screw into the manifold. Once this is done begin reconnecting the plumbing system. Again I can't stress enough that if you are not comfortable or have experience soldering copper to bring in a licensed pro. Nothing worse than completing the job and finding its either not up to code or worse leaks and you have to back over the job. Good luck with your project and let me know if I can be of any further help. Sorry it took so long to finish this. I was out sick for about a week right after I completed the first part. Good luck.
Aug 03, 2010 | Moen & One Handle Tub & Shower Faucet
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
New spout leaks does the copper pipe go to the rubber ring or does it have to go by it
Tub spout has an o ring that pipe goes through for seal. So it should go by it.
May 15, 2010 | Danze & Single Handle Tub And Shower...
When installing a shower temperature control valve should the cartridge be removed before soldering to copper pipes
Yes you need to remove the valve befor you solder the copper pipes on it. If you do not remove the valve you will melt it to the valve body and then it will not be useable.
Mar 02, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen & Replacement Cartridge  Logo
54 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
