Question about Brother HL 2140 Laser Printer
Have setup printer & driver as per instructions.Test print OK. Whgen sending pages to print they get stuck in the print queu until the poer switch on the printer is turne off nad then on again. The printer doesnot print spontaneously.
  • 10,421 Answers
The power button on my hp deskjet 3845 is flashing & not responding to pending print jobs. help
it is possible that the printer as a ink issue or thinks it has a paperjam, another thing that can happen is that the print sent to the printer become corrupt locking the printer in a "i dont know what to do" state.
try to run a test print through the printer using the internal test, this is normmaly done by holding down the power button till the power light blinks it should then spit out a print (do this while unplugged form the computer)
**for full test print instructions refer to user manual)
if the driver has become corrupted it also will send damaged print information to the printer
if the test print works fine than you may need to delete all your queued jobs and then run a WINDOWS TEST PRINT form the driver. if this still does not work reinstall the drivers of the printer
(providing the printer will run an internal print)
Feb 08, 2011 | HP Deskjet 3845 InkJet Printer
After hitting print button,dialog box comes up printing, but there is nothing printing. Per control panel Printers & faxes everything is ok shows D2600 printer ready, per box item in que is printing
Hi there please try these.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 03, 2011 | HP Color LaserJet 2600n Printer
Installed using CD as per instruction manual,
Vista can be installed as either 32 or 64 bit, verify that you installed the 64 bhit system
Oct 22, 2009 | Brother HL-2170W Laser Printer
Windows Home Basic 32 bit and HPC4380 printer setup wirelessly. Have printed ok in the past but now get blank or incomplete pages. Have installed latest Aug 2009 driver and have re-installed many times....
To isolate the exact cause of this issue please print a self test page and check whether the same issuse persists.
Print Self test page:
Please click here and follow the instructions to print a self test page.
If test page is not printed properly then clean cartridge contacts and nozzles.
If issue still persists then replace the cartridges.
Sep 05, 2009 | HP Office Equipment & Supplies
Help! My Officejet 5610xi All in One won't print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab66
Jun 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Apr 23, 2009 | HP Color LaserJet 2600n Printer
Epson Stylus C88 puts the job in the queu and doesn't print
Have you tried running an independent printer check - see
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
If the printer prints the test page OK, it means the problem is with the computer. If it were a PC, I would uninstall, reboot and then re-install the driver software. Maybe this will work with a Mac?
Feb 19, 2009 | Epson CX8400 All-In-One InkJet Printer
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Installed drivers and set up new unit per instructions,unit will not scan or print from any user
open the nprinter folder and confirm that your preinter is set as the default printer,try and print a test page,then send your printing jobs,good luck. eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Lexmark X7350 All-In-One InkJet Printer
Brother HL 2140 Laser Printer Logo
59 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
