Question about Electronics - Others
Help i have failed to open my flash disk and whenever i try to open it it displays first format your flash disk and when i try to format it tells me i have no rights to perform this task
  • krishna9122 Oct 25, 2008
    I cannot format my 1gb micro sd card. When i want to format it, then the message occur "that the disk is write protected?"
How do i put somthing on my usb to a cd
Posted on Jun 15, 2008
Why my san disk usb fash when i check its properties shows only 8mb out of 2gb and doesnt allow to be formatted
Whenever a computer tries to access a flashdisk, even for just retrieving the properties of the disk, a LED will flash.
Not being able to format your disk is another thing. If you've opened a file at this disk, Windows will prevent formatting. Best is to restart your PC, and than immediatelly start the formatting-process.
Oct 11, 2013 | Computers & Internet
I can't seem to remove write protection from this disk to format it. It is and 8gb usb device. It tells me it's write protected whenever I try to fix it.
Try with my property click here , choose download - and download winsetup from usb.
Try format with this software ,
if still error, contact me.I will help you my friend.
Jun 16, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Whenever i try to open my 2GB flash disk the instructions i get is that it is not formated. when i order for formating, it tells me that windows is unable to complete. What can i do?
try this, in start type cmd and you will given to dos mode the type format + drive leeter which assign in wor flash ex. e:/u and put the parameter u
May 30, 2011 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Whenever i insert my 2gb iball flash drive it gets detected but whenever i try to open it it gives the message insert disk into drive
The drive has two components:
* the electronics that tell Windows that it is a flash-drive
* the actual "memory"
In your case, the 1st component is working fine, but the 2nd component has failed.
Spend $10 to purchase a new flash-drive.
May 08, 2011 | Electronics - Others
My flash disk does not format what is the problem? i put the flash in the windows xp system port it becomes recognised by the system i try to open it ,it tells me the disk is not formated do you want to...
Your flash disk has been infected by virus that is why you are unable to open the flash drive. The best thing you can do is to download a good antivirus such as MacaFee or Avira or scan the flash drive for virus.
An alternative thing you can do is to insert your flash drive into a linux operated pc such as Fedora, Ubuntu, Open Susie or Redhat and then delete all the files in the Flash drive and format it
Apr 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Try formatting the flash drive using this method.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 22, 2009 | Transcend (589307) Media
Flash disk displays No media in disk management.
format and see
plus try uisng on some other pc /device to confirm the defect.
u get replacement fm kingston as it has 5 yrs warranty
Jun 22, 2008 | Kingston flash memory card - 256 MB -...
Electronics - Others Logo
97 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
