Question about Canon BJC 80 InkJet Printer
What does disabling bidirectional support mean
I have a bjc 80 (and a 70) and it has a pararell connec to the printer and usb to the dell laptop with xp. The printer either show error and will not print or makes a high pitch sound and trys to print and spits out paper but doesn't print. I have tried several downloads without success. What does disabliing bidirectional support mean?
    Problem Solver:
  • 18 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Posted on Oct 05, 2008
    Guru:
  • 125 Answers
If I understood right you are using a USB to Parallel/Printer port adapter. If that is the case I had the same problem myself. To disable the bidirectional support You have to open the printers properties. In the printers map, right click on the printer and choose properties. then in the "Ports" page, down below there is a tick mark choice with some text like: "Activate support for bidirectional communication" you have to clear the tick mark!
Good Luck!
Posted on Nov 24, 2009
Dell Photo 966 All-In-One Printer Issues. HELP PLEASE.
first purely uninstall and restart download correct driver from dell and install driver without connect printer.once installation completed your computer ask printer then connect it will be ready
Mar 30, 2014 | Office Equipment & Supplies
Esp 3250 just upgraded to win 7 and plugged printer to usual usb bu keep getting . warning bidirectional support disabled. never had a problem before
I just looked at the Kodak website and could only find the following reference - it is for windows xp but you could try and see if it will work with windows 7.
For WINDOWS 2000 and XP Operating Systems:
  1. Temporarily disable the Windows firewall:
    1. Select Start > Settings > Control Panel > Windows firewall.
    2. Disable the firewall and click OK.
  2. For WINDOWS 2000: Select Start > Settings > Printers. For WINDOWS XP: Select Start > Printers and Faxes.
  3. Right-click the KODAK EASYSHARE Printer Dock, and then select Properties.
  4. Select the Ports tab.
  5. Clear the "Enable bidirectional support" check box.
  6. Click Apply, and then click OK.
  7. Check for correct operation.
  8. Restart the computer.
Hope that helps.
Nov 18, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
Installed the scanner program for bjc-80 onto a Netbook with only USB ports...wont recognize printer/scanner,,,help
Netbooks usually doesn't have PCMCIA capability. what you sould do is to disable the bidirectional function of the printer. To disable the bidirectional support You have to open the printers properties. In the "printers and faxes" map, right click on the printer and choose properties. then on the "Ports" tab, down below there is a tick mark choice with some text like: "Enable bi-directional support " you have to clear the tick mark!
Apr 25, 2009 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Slow printing
I'M USING MY BJC 80 ON A PACKARD BELL M35-U-57, VISTA HOME BASIC. CONNECTED THE PRINTER WITH A GENERIC USB-PARALELL CABLE, NO DRIVER. FIRST HAD THOSE 5 TO 7 MINUTES DELAYS FOR PRINTING. WENT TO THE PRINTERS "PROPERTIES", "ADVANCED OPTIONS" AND TICKED "PRINT DIRECTLY", IN THE "PORTS" SECTION I DISABLED "BIDERECTIONAL PORT". IT'S WORKING SWEET. NO MATTER THE QUALITY. ANY COMMENT OR SUGESTION: decoy424@gmail.com
Feb 03, 2008 | Canon BJC 80 InkJet Printer
Slow printing
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Nov 01, 2007 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
1,495 people viewed this question
old marine
old marine
