Question about Wasp WPL305 Thermal Label Printer
My ribbon is coming out with the label. the front spindle is not rolling.
You have to calibrate the printer. It thinks there is no ribbon (thermal mode) so it's not winding the ribbon up. The instructions are on page 11 of the manual -
4.2 Ribbon Sensor Calibration
Note: Please make sure the ribbon is properly installed before doing this calibration.
Please follow the steps below to calibrate the ribbon sensor.
1. Turn the printer power off.
2. Press and hold the FEED button then turn on the printer.
3. The LED will turn orange then blink red 5 times. Release after the first red blink and before the 5rd.
4. If the ribbon is properly installed the light will turn green. If it is not it will turn red and blink.
Posted on Feb 22, 2011
Error message: Ribbon out keeps displaying when there is a fresh roll in the spool, checked everything I could see and find nothing Possible bad sensor?
Check that the metal ribbon blade spindles are in place. these hold the ribbon core in place.Also make sure the ribbon is not loaded over the ribbon reflective plate.( under the head mech where the label guide slot is) Try a manual calibration in the menu.If it asks for a password, its :1234. There could be a slack or broken belt. just fyi: there are (four / 4) belts. The ribbon motors rarely go bad, if all else fails , its probably a ribbon control board.Also check that there is not any junk stuck on the ribbon/ auxiliary roller gear. Sometimes toggle pressure is the culprit.If there is not enough pressure on the head plate, sometimes it will slip.
Jan 21, 2011 | Zebra 110PAX4 Thermal Label Printer Print...
Can not reload lables in the gun
Depending on the type of gun that you have, loading will vary. Here is the most common style of label loading:
Loading
  • At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
    Insert a roll of labels into the gun opening so that the beginning of the roll is at the back and comes up over the top of the gun. Insert the beginning of the roll into the slot, squeezing the trigger halfway. Push the labels through the gun until they come out at the front. Thread the labels up and under the black plate on the front of the gun and then under the rubber roller. Squeeze the trigger again and pull six or seven labels out. Discard the labels, leaving the paper backing. Thread the paper backing into the underside of the gun, next to the handle, in the direction indicated by the arrow. Push the paper backing while squeezing the trigger until the gun begins dispensing labels.ixzz18ERFHy
  • Dec 16, 2010 | Office Equipment & Supplies
    How do you change the ribbon on a Zebra Stripe Sticker 500 Printer?
    put the new ribbon on the black spindle, pass across the metalic plate and the labels, (not unter the plate(here just the labels). and go unther the printhead, and attach on the large spindle.
    Aug 16, 2010 | Zebra Stripe S500 Thermal Label Printer
    My ribbon roller couldn't roll that suppose to be and now the ribbon keep rolling out. (front Roller)
    Check that you are in thermal transfer mode and not in Direct thermal.
    The motors are active only if you are in Thermal transfer
    May 20, 2010 | Toshiba TEC B-472 Thermal Label Printer
    When the roll of black thermal material is used up, how do you get it off the finished roll? Is there a way to reverse the direction of the feed? How is that done?
    grab the roll and at the same time, squeeze and pull toward you. The take-up spindle will collapse slightly and the used ribbon will come right off.
    Hope that helps !
    Apr 09, 2010 | Datamax M-Class 4208 Thermal Label Printer
    There are two spools for the ribbon and one spool for the ticket roll. The first spool on which the ribbon is first attached no longer rotates, while the secon spool still wants to rotate (thus resulting...
    There is one motor and two belts - one belf for each ribbon spool. It's possible the belts are the problem, but it sounds more like it's the ribbon spindle itself. The spindles contain clutches, and when the clutches bind up the spindles don't want to turn. Sounds like you need a new ribbon spindle.
    May 05, 2009 | Monarch 9403 Thermal Label Printer
    How can you take the used ribbon off the printer roll without having to unwind the whole roll?
    In the ribbon take up spindle twist the purple nub counter clockwise then pull the used ribbon...
    Mar 19, 2009 | Zebra S4M Thermal Label Printer
    RIBBON ERRORS
    Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
    - The ribbon roll is not correctly fitted to the spindle.
    - The sensors detecting the rotation are out of order or completetly filled with dust or grease.
    In this case clean the sensors.
    Another reason may be due to Direct thermal printing with a ribbon mounted.
    Mar 02, 2009 | Toshiba TEC BSX5 Thermal Label Printer
    Error code 754
    It's very possible you are not installing the ribbon properly.
    When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
    Do not throw away this plastic core - you need it for the next roll of ribbon you load!
    You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
    You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
    Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
    Ribbon error 754
    Your printer is not correctly configured for ribbon. Download the manual located at ftp://www.servisource1.com/user_documentation/9855/9855oh-ae.pdf
    Go to chapter 4-1 to see the map of the menu system and change your printer to ribbon yes.
    Make sure that your printer is loaded with supplies and the ribbon is set up correctly, as well as slack taken out.
    You may see a couple of labels not print well, but after that, you shold have proper tension and good print. If you notice a lot of ribbon wrinkle, you probably need to reload your ribbon or adjust the tension bars.
    This should resolve any issue you have with the ribbon.
    Ohiotech
    Sep 14, 2007 | Monarch 9855 Thermal Printer
    Wasp WPL305 Thermal Label Printer Logo
    817 people viewed this question
    Top Wasp Office Equipment & Supplies Experts
    k24674
    Marvin
    Marvin
    Are you a Wasp Office Equipment and Supply Expert? Answer questions, earn points and help others
