Question about AT&T Blackberry Curve 8300 Smartphone
Bluetooth headset My supervisior needs a bluetooth headset that is can be used with two mobile phones. Are there any devices on the market that I can recommend to him?
  • 20 Answers
The Jawbone 2 is the best option but theres also a Jabra bt8040 that can also play music, unfortunatly it doesnt have a hook and tends to sit ackwardly in the ear. then there is the plantronics voyager big but does the trick
Posted on Jun 15, 2008
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
Tip
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
86707
86710
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
NOT CONNECT TO MY MOBILE PHONE
you have to check the compatiblity of this device with yout cell phone.
Connectivity Bluetooth version
  • 2.1 with enhanced data rate (EDR)
Bluetooth profiles
  • Handsfree profile (HFP) 1.5
  • Headset profile (HSP) 1.1
if your cell phone has the above features then follow the undermentioned steps.
you need to search for the device by starting a new search after switching on the bluetooth and make sure that the bluetooth headset BH-104 is switched on.
once the search is completed and your device is found then pair it.
after pairing the device you can use it.
Dec 26, 2010 | Nokia BH-104 Bluetooth Headset
How to use bluetooth headset in samsung corby???? plz plz help me
1. Just activate the bluetooth in your mobile.
2. Put your bluetooth headset in discovery mode (for this you may need to press the ON button in your headset for more no. of secs around 15 secs) . Please read the user manual of your bluetooth headset to know about how to put it in discovery mode.
3. After that, search for bluetooth devices in your samsung mobile.
4. your headset should be detected in your mobile. If not, still your bluetooth headset is not in discoverable mode. you have to turn it on and try again.
5. If listed in your mobile, select it and it may ask for Passcoe. Provide 0000 as passcode. Thats all now the bluetooth headset is connected to your mobile. If passcode is not accepted, then please do refer the device manual to know about that.
I hope this is useful to you.
Thanks
May 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I cant talk to anyone and how do you talk to them
Check to make sure that the bluetooth headset is compatible of connecting to the mobile device. If it is, then you will need to pair the devices using the Mobile Device. Make sure the Bluetooth Headset is switched on when the Mobile Device is trying to search for the Bluetooth Headset. It should work but if it doesn't, check the Manufacture's Website for any support.
Oct 21, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Unpairing bluetooth headset without mobile???
You may be having compatibility issue instead of what you suspect may be wrong with both your phone and the Bluetooth headset your friend gave you.
Well, there is no such thing as a Bluetooth headset being permanently locked in to a phone.
As long as there is an open 'visible' Bluetooth connection option and there are devices in range ready to pair, the process to pair starts.
Whenever there are incompatibility issues, pairing two devices using Bluetooth becomes a hassle.
Oct 11, 2017 | Nokia N76 Cellular Phone
Motorola bluetooth headset HS850
There are several possible reasons for this problem.
Try the following steps:
- Shut off the headset.
- Shut off bluetooth on your mobile phone and restart it.
- Now bring your headset in pairing mode. How to do this should be explained in the manual.
- go to something like "add new bluetooth device" on your phone. Something like that should be in the bluetooth menu.
- the phone should find the headset now. Pair the devices using pincode 0000. That's normally the code for headsets.
you can use the headset now.
If one of the steps gives problems, just ask. Then I will try and give some more specific help.
Please give some reaction also if this was helpful...
Ruud
Oct 31, 2008 | Motorola Mobility Universal Wireless...
Motorola H350 Bluetooth headset
Ineed my pin code for h350 bluetooth headset
Sep 22, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
AT&T Blackberry Curve 8300 Smartphone Logo
60 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
