Question about ASUS P5P800-VM Motherboard
Bro when this error appear system halted! the system is hang (stop) and cannot go to the bios....you can change your processor's heat controller.....if not work...then this problem is in your motherboards main chip.....so change the motherboard.....
  • 231 Answers
SOURCE: Motherboard BIOS
Hi, your motherboard and Bios settings are both ok.
The problem is most likely your hard drive. I reccomend you check this by pressing the delete key repeatatadly at start up to enter the bios settings. at the first screen you should see if your hard drive is recognised [ primary master]. It may be time for a new drive or for a reinstall of your operating system.
Regards mistyman
Posted on Nov 07, 2007
colliewob
  • 781 Answers
SOURCE: IBM Motherboard
Check the motherboard battery it could be flat and if it is BIOS is continually reset.
the Battery is a shiny round object about 19mm across and has a number on it only replace with correct number
The reason it eventually starts is the power gradually resets battery for a short while
Posted on Oct 23, 2008
cpenzes
  • 1102 Answers
SOURCE: Compatable gigabyte ga 81915pm motherboard
you may not have to format
you should be okay
are you sure power supply is not going
remove cd drive and boot see if you can get to safemode
Are you sure you have'nt had pc opened and maybe loosened a memory
I still don't think it's the motherboard.I would go more for a memory or power supply problem
let me know
Posted on Feb 13, 2009
  • 4 Answers
SOURCE: motherboard crash bios
1st remove ur mother board battery and clear cmos and press reset when machine start then shut down and change a new battery and fixd cmos. i hope ur problem will solv
Posted on Mar 17, 2009
tecnomage201
  • 221 Answers
SOURCE: chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Posted on Jul 21, 2010
Windows XP sp3 not booting Error system halted
Is your First Boot Device in BIOS is Set to Hard Drive? IF not then Just Change it Hard Drive.
Aug 11, 2012 | Intel Computers & Internet
167 bios
To troubleshoot processor issues, follow these steps and test the processor after performing each one:
Notes:
  • If either the system board or processor have been replaced, reflash the BIOS to the latest level before proceeding.
  • Some computers allow the fan to stop spinning. This is not a malfunction. The fan should start spinning as the system heats up.
  1. Ensure the latest BIOS code is installed. This will correct any 167 POST errors for the Intel microcode update and "176 No Processor CPUID" post errors.
  2. Reseat the processor and the heat sink
    Note: Do not touch either the processor or system board contacting surfaces. These can be extremely fragile and bent pin damage due to touching is not covered under warranty.
  3. Verify the processor fan operation is not blocked by cables or other hardware.
  4. Verify that any replacement processor is the correct architecture for the system.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | IBM NetVista PC Desktop
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
My Pc is getting hanged often
it is problem oparating system is crass or processor is over heated chack it then solve this problem
Aug 27, 2009 | Intel D101GGC Motherboard
New system hangs at p.o.s.t
I would first clear the cmos. Then try to get back into the bios and check the ram voltage setting. My Asrock board AOD790GX128M had me use the #3,4 memory slots, the #1,2 gave me the bsod. You may want to try that also. I hope this helps you.
Aug 13, 2009 | Asrock 4CoreDual-SATA2 Motherboard
The service tag is 19sfy91. At first I could not get past BIOS error "Alert! System Halted. Incompatable processor" I flashed BIOS and the PC boots up but I still get the error message with option F1 to...
The new series of Intel G1 stepping Pentium 4 processors (Prescott) is not backwards compatible with all the latest BIOS versions for OptiPlex systems.
Jun 05, 2009 | Dell OptiPlex GX520 PC Desktop
5B Interface or Device(s) Error, System Halt
It could be Memory module problem which is fixed in 5B slot (or) 5B slot itself may have the problem,
Mar 14, 2009 | Acer Altos 1100 Server
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
ASUS P5P800-VM Motherboard Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
