Question about Canon PIXMA MP150 All-In-One InkJet Printer
EORROR E6 LIGHTS FLASHING ON B AND C WITH SOLID LIGHT ON THE TRIANGLE WITH A JAGGERED LINE IN THE MIDDLE. TRIED TO USE REFILLED CARTRIDGES BUT IT WOULD NOT ACCEPT THEM AND NOW TRYING TO USE ORIGINAL CARTRIDGES
  • Anonymous Nov 18, 2008
    Exact the same Problem here.
  • Anonymous Dec 04, 2008
    the same
  • 232 Answers
It is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release it.
Posted on Apr 14, 2010
  • Ana Cvetinovic Apr 14, 2010
    Turn the printer off. Leave it be for about 10 min. Then, turn it back on. Try doing the reset. If it doesn't work, one of your cartridges might be damaged.
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
We can not find the manual on our Sharp AL-1631 copier. At first the light (shaped like a Z) came on to the left of the green button and we turned off the machine and now that light is off but a flashing...
The flashing red triangle which should look like a stack of dots is your toner cartridge empty indicator. You will need to replace the toner cartridge with a full one or have your existing one refilled. A manual for this discontinued machine will be difficult to find.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Sharp AL 1631 Copier
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
PIXMA MP210 Photo All-In-One Printer: Alarm light is on and I have just refilled my cart...
Hello!
I work in a refill shop, and we have noticed that after refilling cartridges for Pixma MP210, they won't work.
Try holding the "resume" button (triangle in circle), for about 10 sec. for each cartridge- that should reset the cartridges (and usually it works with every Pixma printer, but almost never with the MP210, I really don't know why)
If that doesn't help, you should buy new cartridges.
May 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
No print on Canon Pixma MP150
it is problem your printer black cartridge .Black cartridge is signal E 5 color cartridge is E6.please change it you buy a new original cartridge
black ink cartridge chip is demage
Jul 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
HP Laser Jet 1320. Orange light next to triangle symbol keeps flashing. This began after a paper jam. I cleared the paper jam but can not get the light to stop and so it wont print. I have shut it off...
You can also try:
Apr 09, 2009 | Office Equipment & Supplies
Disconnected printer
If the lights are solid -
The error is caused by a defective cartridge, an unsupported cartridge, an invalid refill, or a cartridge meant to be used in another geographic region.
• If the print cartridge is not installed, install it.
• If the print cartridge is installed, remove it and install a new print cartridge.
If the lights are flashing
This means the photoconducter kit needs replacing
Sep 07, 2008 | Lexmark E240 Laser Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
666 people viewed this question
old marine
old marine
