Question about Leviton #601-6696-I Ivory Wireless 3WY Switch
I have a levitron 6696-I remoter switch installed in my living room. This switch feels very hot to the touch. Is this normal or is something wrong?
Remove a hot wiring device immediately.
This is not safe.
I just found your post, and am going to send the response now without discussing the dimmer.
You can add a comment and get in touch with me.
Posted on Nov 03, 2010
Temperature gauge cold then back to normal
You have to make sure the thermostat is working properly and is the correct one. Idle the vehicle for about 20 minutes and then feel the upper radiator hose. It should be hot to the touch. Drive the vehicle and when the temp gauge falls to 'cold' stop and feel it again. If it is much cooler to the touch than before the thermostat is defective or wrong.
Mar 23, 2014 | 2000 Ford Ranger SuperCab
Anywhere switch erratic
radio freg. can interfere with eath other
Nov 11, 2012 | Leviton Anywhere Switch - 6696-W - White
Installed 6696 When turned of the lights flicker light bulbs are energy saver not incadescat
This switch is made for incandescent load only up to 300 watts.You will need to find another type of switch or change your light bulbs to incandescent bulbs.
http://sbeelectricandhvac.com/
May 23, 2011 | Leviton Anywhere Switch - 6696-W - White
I presently have two three way switches controlling a light. I would like to ad a remote switch to control the light.
INSTALL THE 2 WAY SWITCH ON THE BLACK WIRE FROM THE LINE IN. THIS WILL CONTROL THE POWER TO BOTH 3-WAYS NO MATTER WHAT POSITION THEY ARE IN.
Jan 23, 2011 | Leviton Anywhere Switch - 6696-W - White
How does levition 6696 switch work?
The Leviton 6696 Anywhere RF(Radio Frequency) lighting control allows you to add an additional (wireless) switch to an existing switched light(s) without having to hard wire it. For example, let's say that you have a bedroom with a switched overhead light. The Leviton 6696 RF receiver would be installed in place of the existing light switch. It will still function and is wired the same as an ordinary switch. The Leviton 6696 Anywhere RF transmitter (after installing the batteries) can then be used anywhere within 50 feet of the receiver (that replaced the existing light switch) to also control the light. You don't have to mount the transmitter if you don't want too. It can be on the night stand, (or carry it with you if you want) so you can turn the light ON and OFF from the bed or wherever.
Oct 21, 2010 | Leviton #601-6696-I Ivory Wireless 3WY...
Freezer is hot on the sides is this normal?
Good day,
Yes, that is normal. It is ideal to not be in a hot room but as it reaches temperature and begins to cycle off and on it will become somewhat cooler.
Jul 20, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Newly installed Leviton dimmer switch humming at the switch
Unfortunately, the hum is normal for operation of that type of dimmer at low levels.  Sometimes the lamp filaments will also "sing" a high pitched sound.
Mar 17, 2009 | Lutron #D-600PH-DK 600W SP Push Rotating...
Aircon wont turn on
well check ur batteries in ur remote control unit and replace them with new ones instruction to do this u will find in ur user guide......
Mar 07, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Leviton #601-6696-I Ivory Wireless 3WY Switch Logo
125 people viewed this question
Top Leviton Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
