Question about Polaroid FLM-3232 Television
Polarid 32inch lcd
Where can i get a new power supply from rather then polariad fpr parts ?
  • 51 Answers
If you can't rebuild the power supply you will have to purchase the entire "control box" from a dealer...vance baldwin is one. the part # is 909-KS0-GF321XAH warning..the price will be close to replacement cost...
Posted on Jun 25, 2008
I don't have a problem to the solution,but my tv is not working it wouldnot comeon it appears that polorid has a problem with the pwer supply
Posted on Jun 24, 2008
Philips 32inch LCD tv.. when powered on runs fine for 5 mins and then it flicks and double image starts.. What will be the problem???
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 19, 2015 | Philips 32PFL3403D/27 32 in. LCD TV
32inch Samsung LCD sparked at back now won't turn
Replace the power supply board. You can get the replacement power supply from www.tvrepairworld.com
Dec 13, 2012 | Televison & Video
Toshiba tecra A9 when I press the power button I get the power indicator light and the hard drive light. The hard drive starts to spin for about 1 second and everything shuts off and all the lights are...
there is a short circuit in your laptop. the power circuit cut off the power fpr protect the circuit. need to dissemble and remove parts cd hdd and ram other parts you can remove. power up and check the continuous run , no need video, after replace the ram test the display. also your lcd is bad or converter may be shut off, there test without lcd.
Oct 06, 2017 | Toshiba TECRA A9 PC Notebook
I have a vizio 32inch lcd, i was watching tv normally and then boom, it completely turns off, no yellow light, no blue screen, nothing, i tried connecting the cord to a different outlet and everything,...
well in this case maybe you have problems in your tv power supply. you need technician to cheack it..... as you said everything in your house electricity is okey.
May 30, 2011 | Vizio L32 32 in. LCD HDTV
Can i get my 32inch ambilight screen fixed ,it has a crack on it .
Hi Raverbaby768,
I am Sorry that you LCD 32inch screen cracked.
and I Fear the costlies part of LCD TV's is the Screen.
Yes, the screen is the most expensive part of your entire TV. The cost of repair + transportation will likely equal to or exceed the cost of a new TV.
I would suggest you to try fixing the screen in the near service centre.
If my Solution is informative, kindly vote.
Regards
BEADHZ
Apr 09, 2010 | Astar LTV-32ASB 32 in. LCD Television
My lg 32inch hd ready has a problem the power can't through tv i'been changed the fluge fuse yeastrday still have the same problem
You would need to get a multi-meter & check which voltage supplies are coming from the power supply to the other stages of the TV, such as the 25v / 12v / 5v supplies. If these are missing then you need to locate which regulator in the power supply has failed, if these are present then you need to establish which part of the circuit they supply eg the 25v rail for the inverter board etc. It is most likely if all the supplies are present, then there will be a fault in the main board which is not initialising the start up procedure.
Dec 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Vizio 32inch lcd
Well if the inverter board is bad it won't come on... Power supply is a switced mode so even if you don't see bad caps don't mean it ain't bad.
Jul 23, 2008 | Vizio L32 32 in. LCD HDTV
Polarid tv-dvd combo power trouble
TROUBLE WITH REMOT CONTROL. I CANNOT PROGRAM MY DIRECT DISH
Jan 02, 2008 | Polaroid FLM-3225 32 in. LCD Television
Polaroid FLM-3232 Television Logo
100 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
