Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
The Maxtor harddrive was moved and the plug got jiggled so it wasn't showing on my pc...I fixed the issue, then kept getting an error message "checking dish one touch" with 2 choices...automatically fix file system errors, and scan for and attempt recovery of bad sectors...I chose both, and lost a complete file that had 72 items in it...I tried another way to view contents and it say my maxtor had zero files...later I was able to determine that apparently the 1 file was the only thing lost, but how? Can I recover this file? Is the rest of the harddrive in danger of being wiped clean? I used my antivirus scan, and malwarebytes to make sure nothing has invaded. Help!
    Brigadier General:
  • 10,406 Answers
Open My Computer
Note the drive-letter assigned to the Maxtor
Close My Computer
Click Start
Click Run
Type CMD
Press Enter
If the drive-letter was 'E:', type 'E:'
Press Enter
Type ATTRIB -H -R -S *
Press Enter
Open My Computer
Double-click the icon for the Maxtor
Does it still show "zero" files/folders?
Does it show a 'FOUND' folder?
What file(s) are in that folder?
Posted on Nov 02, 2010
The heads on my harddrive move back and fourth constantly
try to access it from another computer through a USB adapter. See if the files can be read. This will tell you if the drive is bad or good
Aug 18, 2009 | Computers & Internet
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Problem Installing Maxtor External Drive
no solution but just wanted to say I have the same problem, please let me know if you do find a solution because I have a lot of files on it and would love to get them off
Sep 24, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Harddisk
Can you recall what you were doing when you first got that error message? Try disconnecting the drive and then reconnecting it. If you still get the same message, check the Maxtor utility to see if there is some type of repair procedure that you can do without reformatting it.
Aug 23, 2008 | Maxtor Hard Drive
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from www.thefreecountry.com/security/securedelete.shtml
Jul 21, 2008 | Maxtor Hard Drive
Did a system recovery on pc now can't find my harddrive
Hi Shannon,
yes, you could - and should - connect the external harddrive directly to your pc in case it throws errors. You will need to do this in any case to figure out, what is wrong with the drive.
Connect the USB cable to your PC and check whether the drive is recognized by your Operating System. If it fails to be detected get back to us and we will try to help you.
Jun 30, 2017 | Maxtor OneTouch III Mini Edition (R01E100)...
Error performing inpage operation
I've just fixed the problem of error performing the inpage operation by using old DOS command CHKDSK <driveletter> /F. And, i'm satisfied with the MS-DOS command.
Jun 18, 2008 | Computers & Internet
Maxtor One Touch 4 500 GB External Hard Drive (Windows XP (SP2) - I have an issue with my harddrive, where when I plug it into the USB, initially the power light comes on & beeps but it is not showing...
Had same problem. I shut down computer and restarted and Maxtor was installed and had desktop icon and everything worked then. I then backed up with no problems.
Apr 14, 2008 | Computers & Internet
Reg: User creation and folder creation problem,
Possible solutions.
1- Reset your harddrive using a pin through a little hole behind the drive.
2- Update the hard drive bios
3- download the lattest drivers.
Aug 17, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
229 people viewed this question
Top Maxtor Computers & Internet Experts
Phil Whisenant
Phil Whisenant
Alun Cox
Norman Al-Anbar
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
